Subaru Tech All We'll Drive
boost cut
Old Dec 14, 2009 | 09:50 AM
blacksti's Avatar
DudeMan
You should ALWAYS do a boost leak test before tuning, but more then likely he didn't change the value for fuel cut like stated. Same thing happened to me when I got my first tune.
2jz mustang build
https://www.tamparacing.com/forums/g...l-project.html
Old Dec 14, 2009 | 10:00 AM
concordcobra's Avatar
Breakin tranny's
Sounds like you should go to someone who knows how to tune an STI....
Old Dec 14, 2009 | 10:33 AM
schoellnasty's Avatar
Originally Posted by zenith
OK well what would you guys do in this case cus it could be vaccum lines, a mechanical problem, or the tuning. Should I take it to a shop.
Well there is a way to find out if its a tuning/BCS issue or a mechanical issue with the wastegate. If you run a line directly from the turbo outlet to the EWG and do a WOT pull, the car should hit 1 bar exactly and hold rock solid. If that happens you have a problem with how your BCS is hooked up or a problem with your tune. If it makes more than 1 bar then you have a problem with the wastegate.
Old Dec 14, 2009 | 05:50 PM
zenith's Avatar
Figured it out guys. Mechanical problem with the waste gate. thanks for the replies.
C:\Documents and Settings\Khursheed\My Documents\My Pictures\Picture\800px-2006_gsxr750.jpg
Old Dec 15, 2009 | 06:46 PM
[Duy]'s Avatar
The Asian
Log off my name next time u post ass lol
