Subaru Tech All We'll Drive
boost cut
Old Dec 13, 2009 | 04:55 PM
[Duy]'s Avatar
The Asian
Default boost cut
So I just went to go get tuned. I have a 2007 sti. My mods are 38mm ewg, TBE, GMBS and fuel pump. It was a road tune. When we got on it in fourth we would get boost cut at about 5000 rpms. The duty cycle would just drop to 0. I checked all the connections and I didn't see anything wrong. My tuner thinks its that I have to strong of a spring in the waste gate but its only 1bar. I need help guys cus I really don't think the problem is that I need a .5bar spring. Thanks for your advice.
Old Dec 13, 2009 | 07:22 PM
specVmatt's Avatar
400hp club, barely
Maybe he mistakenly tuned your Cobalt?
Coyote
Old Dec 13, 2009 | 07:47 PM
schoellnasty's Avatar
What is your target boost? Were you hitting that target at all before the wgdc hits 0?
Old Dec 13, 2009 | 07:55 PM
blacksti's Avatar
DudeMan
Did I rub off on you?
2jz mustang build
https://www.tamparacing.com/forums/g...l-project.html
Old Dec 13, 2009 | 08:15 PM
zenith's Avatar
It's my car guys. It hit 22 psi and then cut. Target boost was 19
C:\Documents and Settings\Khursheed\My Documents\My Pictures\Picture\800px-2006_gsxr750.jpg
Old Dec 13, 2009 | 08:40 PM
blacksti's Avatar
DudeMan
Probably fuel cut
2jz mustang build
Old Dec 13, 2009 | 11:27 PM
zenith's Avatar
I doubt it cus my check engine light came on and it read something about the duty cycles.
Old Dec 14, 2009 | 04:49 AM
specVmatt's Avatar
400hp club, barely
lol.
Well whenever I hit fuel cut, it was when I overboosted around 3 psi over target boost and I would get a Wastegate CEL, I agree with it being fuel cut man.
Coyote
Old Dec 14, 2009 | 07:01 AM
Fuel cut on a stock 07 ROM is set at 33.55psi absolute, so just under 19psi of boost. Your tuner needs to increase this value if he hasnt already.
I dont think you need a softer spring. Ive never heard of anyone boost creeping on a properly setup EWG, especially by 7psi over spring pressure. Hell I get creep on my 15psi actuator but only by a couple psi at 6K+. And this is on an internal gate too. My guess is that you either have a vacuum line hooked up wrong between the BCS, wastegate, and turbo, or there is a mechanical problem with the wastegate that is preventing it from opening fully.
Old Dec 14, 2009 | 08:46 AM
zenith's Avatar
OK well what would you guys do in this case cus it could be vaccum lines, a mechanical problem, or the tuning. Should I take it to a shop.
