Need some trouble shooting help
So, it doesn't make the noise in neutral with the clutch engaged?
When it's happening, does it change sound if you place some pressure on the shift lever (try different directions)?
[ Stage Infinity ]
[ Stage Infinity ]
It still isn't difficult to shift gears. I'll check if the noise changes when I put pressure on the lever.
the gear clusters in your transmission are spinning at all times even in neutral so you would hear it all the time if it was related to the gears. that if is intrnally related but i doubt it. could be center diff/front diff does it go away depending on if you push the clutch in or out
Random question, but is 5th gear in your transmission direct drive? If it is that might be why it gets louder since the driveline is locking in sync with the engine. If not then I just made a useless post
their is no perfect direct drive that goes from input shaft to out put shaft like i said all gears are spinning at all times except center diff and front diff it could be somthing else in the tranny but doesnt sound like the clusters
After I drain the fluid this weekend, I'll get my video camera and record the noises it's making.
Could a bad rear diff also send noises to the tranny? I mean it is directly connected to it through the drive shaft.
Oh and I put pressure on the lever while in gear and I did not getting any change in noise that I could tell.
Okay, so an update. I haven't changed the fluid or anything, but I did notice something today. I had to accelerate into traffic and it seemed like the car was having trouble putting power to the ground, especially when on a slight curve.
Normally when I'd drive the car easily for a week and then get on it, it would feel pretty damn quick, but today it just felt slow. I have not had any motor issues, no CELs, nothing.
Oh and clutch is still new, around 6k miles on it.
