Need some trouble shooting help
So yeah, 6 speed may be coming sooner than I expected
I have this ticking/whirling sound I hear coming through the shifter that is directly related to speed. The faster I go, the louder the noise is. Doesn't matter whether the car is in gear or not and the only time it goes away is when I come to a stop. You can also hear it from the outside when the windows are down.
I'm guessing a chipped tooth on one of my gears, huh?
No nails.
I thought that at first, but wouldn't wheel bearings hum when they are going out and not make a rattling sound?
At low speeds under 20 just coasting it sounds like tapping/ticking noise. Above that is when it starts making a whirling sound and at 60 it's almost a whine.
I need to get the thing up on jack stands or a lift and have it in gear coasting and listen to where the noise is coming from. I just need to find time to do that.
Also I need to figure out whether to rebuild the 5spd, find a junkyard 05+ LGT 5spd or do a 6spd. Even though I'd like a 6spd, I need to go with the best "bang" for the buck option.
I'll also borrow 2 jack stands from my buddy so I can get all 4 wheels off the ground and pin point the sound. Going by a thread I found on NASIOC, it doesn't sound too good for me, but we will see once the weekend comes.
