TGV deletes
Hey guys. Just wondering where you guys got your TGV deletes. For example did you do it yourself, order it from APS or send it somewhere in the mail. Also if you know anyone in the Tampa area that does this that would be great or if you know how to do it I could pay you or buy you beer lol. Thanks.
do it your self. pull intake manifold off 4 12mm bolts each side and then unbolt tgvs from the intake like 4 10mm bolts each side take the butterfly off 2 screws on each butterfly take sensor off eachside and pull the rod out 'slides right out' have holes welded where the rod went through 4 little holes probaly cost you 10$ and really want it to be good grind out the section that is in the port or what ever you want to call it.
its easier to remove the TGVs and the manifold together, but you need to disconnect the wire harness underneath and the clips for the injectors and disconnect the fuel rail completely and remove it all in one piece.
If you have been mislead or fraudulently persuaded into buying a timeshare in the last 2 years.. I CAN HELP!!
i can pull and swap tgvs in 45mins or less.. its really not hard people
