Subaru Tech All We'll Drive
Bcs925's mods and dynos
Old Mar 4, 2009 | 05:49 PM
bcs925's Avatar
Default Bcs925's mods and dynos
I wish I would have started this earlier (either on here or just personally) but I guess I'll start now at "stage 2". I am going to make a log of my mods and power output (using a RomRaider member's spreadsheet to make graphs). Figure as I keep track of my stuff I'll share and perhaps others might find this useful. (old stuff moved to post #2)
Car:
2007 WRX TR
**Update 4/22/09**
I have purchased a VF39 and Sti TMIC. I will be port and polishing the turbo (hot and cold side), IC ypipe, and IC outlet. I will also be heat wrapping my downpipe.
Timeline:
PnP: 5/1/09
Install: 5/16 or 5/17 if I can find somewhere/someone to help me do it... it sucks not having tools/garage... anyone wanna help? I can supply food and beer
Suggestions? Questions? Comments?
WRX TR... Tampa Racing Edition... because its sure as hell not Tuner Ready
Old Mar 4, 2009 | 05:50 PM
bcs925's Avatar
Addded a Grimmspeed EBCS. Spool slightly increased. I also adjusted the tune. As far as road dynos graghs I will post later (on my laptop). HP/TQ numbers were about the same but the boost spooled quicker and held slightly better. (graphs also to come)
03/04/09
Current Mods:
3in catted downpipe tapered midpipe to a prodrive axleback (2.5in)
TB coolant bypass (perhaps negligible, but figured I'd mention)
Miles when pull was done: 27k
Temp: 57ºF
Dyno:
Old Mar 4, 2009 | 06:01 PM
ShockerGT's Avatar
Shake n bake
Nice #s
Old Mar 4, 2009 | 06:35 PM
albie1kanobi's Avatar
The one and only.
if your already tuned i would wait on a new tune till you have enough mods were tuning for. like adding a vf39 or something.
"Is it blaspheme to swap a 4G63 into a Subaru? "
Old Mar 4, 2009 | 06:48 PM
bcs925's Avatar
I have to retune for the BCS... my car wouldnt run with its current tune. I already have a base map for a 3 port bcs so its not going to cost me anything.
Old Mar 4, 2009 | 08:06 PM
blacksti's Avatar
DudeMan
and he tunes himself
2jz mustang build
https://www.tamparacing.com/forums/g...l-project.html
Old Mar 10, 2009 | 08:03 PM
bcs925's Avatar
Default Better Spool?
I wasnt able to do mods last weekend but I definately am this saturday (3/14). I will definately be doing PnP headers and IC elbows and maybe Prodrive ypipe (I'm buying a new one, the 07 version, anyway...).
In the spirit of !!Tampa Racing Subaru Tech Speculation Extravaganza!!...
The mods I will be doing claim 10-15 whp/tq (and no I'm not doing this in hopes of getting this but hey if it happens that would be nice, I really just want to work on my car) and increased spool... well below is my boost vs rpm.... is it actually possible to increase this? Speculate away
Yes I know its not that nice of curve, hopefully my EBCS will help that in 2 weeks. Also I dont kid myself I end pulls at 6k.
Old Mar 10, 2009 | 08:08 PM
LDadrenaline's Avatar
yeah, I drive a miata
porting headers will give you better top end, but won't help your low down torque at all. If the turbo isn't ported, look into doing that. Just a light porting of the inlet and outlet will provide some sound gains.
[/center]
Old Mar 10, 2009 | 08:16 PM
bcs925's Avatar
Porting the turbo would be a project for another day for sure, and I go back and forth on whether or not to upgrade (probably vf39)... Seems like kind of PITA to get to, I suppose I'd have to remove it and I've never done that. I've never removed headers but they are just pipes so I think I'll be alright.
Old Mar 10, 2009 | 08:20 PM
3gsucks's Avatar
the earlier you start in the gear the fast spool with seem to be. so if you start a 2k it may seem to spool earlier than if you start at say 2500.
how fast do you want it to spool i know it will spool by 2800 if you start at 2k
the bcs may help a little on spool but it will mostly help it hold boost better.
when testing for gains try to be as consistant as possible so start on the same stretch of road at the same rpm to be the most consistant with gains.
6 letters spell it, 5 lifters be ticking on it, 4 cams spinning on it, 3in cutout on it, 2 heads flowing on it, 1 turbo creeping on it, SUBARU.
Osecuroms.org Opensource Stage II 2006 wrx 281 downloads and counting
Pm me about Subaru Tuning
