Not making the power
JE pistons/JE rings, Cosworth race/main bearings. You can go with rods, but they are strong enough for what you have.
If one were to build a motor for my setup, and it was somewhat on a budget.. what should they go with? I know pistons and sleeves, but should i do rods and everything? im not looking for an 800whp car. i honestly will probably never get rid of the dom 3. i would like to be able to up the boost to maybe 24 psi, but if i wanted to go to the extreme of 27-28 psi, what kind of money am i talking about putting into the build?
Sounds like the ECU might be using the Failsafe OL Fueling map. What kind of EM were you tuned on? Can you post up some datalogs? Its possible that your IAM dropped for some reason and the car is using the failsafe fueling and timing maps. This would explain the loss in power.
its does sound like a fail safe map, but resetting the ecu should cause it to go back to the normal fueling map.
if the Limit sti is stock with that stock dp he should not be out spooling you by to much. And once the turbo hits it should be a freight train.
6 letters spell it, 5 lifters be ticking on it, 4 cams spinning on it, 3in cutout on it, 2 heads flowing on it, 1 turbo creeping on it, SUBARU.
Osecuroms.org Opensource Stage II 2006 wrx 281 downloads and counting
Pm me about Subaru Tuning
well i may have found the problem. i used seafoam the other night, after that is when the problem began. i was talking to taylor at s and r performance and he said seafoam will make the car run like crap for awhile, but eventually fix itself. the only problem the car seems to have is that its running rich. but its weird that is drops to 10.0 and shoots back to a perfect 11.2.
Coyote
Coyote
first if your hitting full boost at 4200, thats off. dom 3 is capable hitting full boost at 3200 to 3600 depending on setups, anywhere from 22psi to 26psi easly. being ball bearing helps. mine is 22psi at 3400, maybe sooner.
second if full boost is in fact at 4200 the 07 stock should be 14.7psi at around 3600rpm (again this is stock tune). even at this rate you should be pulling him with no problem whats so ever, if your tune is right.
my car with a dom 3, i think my afr stars at about 11.0 at WOT and works its way up to 11.3. i'll double check. 10.0 is rich that instead of making power your probably losing power. i dont even think stock tune is that rich. its probaly why he's keeping up with you. he's making more power down low cuz he not running as rich down low with stock turbo.
"Is it blaspheme to swap a 4G63 into a Subaru?
lol, hopefully thats all it is. good luck
[/center]
[/center]
