need advice on 04 STI
more then likely the BOV is a NON recirculating type and will make the motor run rich. This may be the reason for it feeling slowish? Definately sounds like a kid had this before with those two mods done he wanted you to hear him coming on a short budget
short budget and 04 sti doesnt go together
unless they have the recirculating fitting coming off of the end and returning to the inlet pipe, it isn't recirculating...it will make the car run rich...that and 13psi is about 5 less than factory...Might explain why it feels as slow as an ITR...?
You can probably pick up a less screwed with 05 for about the same...the 05's are better anyhow too.
agreed
98 E36 ///M3 Sedan
07 Civic Si Sedan
98 E36 ///M3 Sedan
07 Civic Si Sedan
i didnt EVOs were that high of boost stock.
