help?
Well seeing as I already saw he has an Access Port yes the warranty on that clutch is VOIDED....
Naw just playin
bring it in and leave the Access Port in. Your warranty wont be voided. You will have to authorize 6 hrs tear down time to inspect the clutch and flywheel, but the only way the warranty would be in question (not voided, we dont have the authority to do that) would be if there were signs of abuse... But If you haven't abused it you have nothing to worry about. Bring it in and I'll have the master tech take a look at it. We might have the parts in stock but I doubt it, most likely have to order them, but if the car is downed SOA will cover the cost of the rental. So give us call and set something up.
Manny
Naw just playin
bring it in and leave the Access Port in. Your warranty wont be voided. You will have to authorize 6 hrs tear down time to inspect the clutch and flywheel, but the only way the warranty would be in question (not voided, we dont have the authority to do that) would be if there were signs of abuse... But If you haven't abused it you have nothing to worry about. Bring it in and I'll have the master tech take a look at it. We might have the parts in stock but I doubt it, most likely have to order them, but if the car is downed SOA will cover the cost of the rental. So give us call and set something up.Manny
"squeak" means just about nothing via internet, but it sounds like it may either be the slave cylinder pin squeaking against the throwout arm or the throwout bearing.
BTTS, STFU&D
BTTS, STFU&D
if you authorize the 6hr teardown and they decide to not honor your warranty, though, you will have to pay for those 6 hours... just fyi
[/center]
[/center]
