Subaru Tech All We'll Drive
Speed-o-meter and tach-o-meter???
Old Aug 1, 2007 | 12:58 PM
  #51 (permalink)
Svenerachi's Avatar
only problem with turbo's on these engines is that you are limited to 5-6psi, due to weak internals(rods and bearings). oh and the 3500 dollar price tag(AVO turbo kit), not including labor and everything else you'll need
superchargers are fun, there is a guy on NASIOC (Reddevil) that ran a 2.2n/a with an eaton supercharger, small turbo, and nitrous on a stock engine.... blew 3 of them sky-high But a small boost supercharger would give you a good amount of gains and still be reasonably priced (ebay!)
read up on NASIOC for the superchargers before you consider doing it... alot more involved than you'd imagine.
Old Aug 1, 2007 | 04:30 PM
  #52 (permalink)
TYJaMO's Avatar
aka EJ20T
thanks for the insight..i'll do some reasearch on it...and about the brake launch never done it...also if yall want we can make it a subaru day at auto-x sometime so i can learn more.
Old Aug 1, 2007 | 07:00 PM
  #53 (permalink)
Alizarin's Avatar
Gravel fiend
Doesn't have to be a Subaru day to come enjoy an auto-x... register! I'll be there, jblaine will be there, probably a few others too. It takes a while before you start getting into the realm of needing somebody who's experienced auto-x-ing AWD cars to learn new things.
What happened to racing for pinks?
Old Aug 1, 2007 | 07:54 PM
  #54 (permalink)
Svenerachi's Avatar
lol
again, don't brake launch, you're going to need a new torque converter, which is upwards of 700 bucks for a stock replacement... if you want to shift like a manual and save your torque converter, save the money and get a shift kit, like the one on IPT Performance Transmissions Torque Converters and Transmission Parts for Ford, GM, Chrysler, and Import vehicles its about the same as a new torque converter, and will give you complete control over the transmission
or else just floor it and let the transmission shift as it will, because otherwise you're going to destroy your tranny shifting it from 1 to 2 to 3 to D...
Old Aug 2, 2007 | 09:17 AM
  #55 (permalink)
bcs925's Avatar
Originally Posted by Alizarin
Also, how about another view on the whole 2.5i situation? Instead of a WRX swap, why not take advantage of the higher compression and go with a supercharger kit, or low-boost turbo? Running 7-8psi will give you a nice power boost, you might not even have to run an intercooler, you will still have power and torque off boost as well, and would probably be cheaper than an entire engine swap to boot. I realize that having a big e-penis and running 50 billion PSI of boost seems to be important around here, but if you haven't figured out that I sorta go against the norm of these boards already, you should pay more attention.
+1.... I'd be interested to see what kind of numbers you put down with supercharger
Old Aug 3, 2007 | 05:51 AM
  #56 (permalink)
Svenerachi's Avatar
you're still going to run into the same problems with the supercharger... you're only going to be able to push 4-6psi max with your engine, which would make you either as fast, or just slower than a stock wrx.
