Subaru Tech All We'll Drive
HOW TO: Area1320.com VF30/34/39 IWG bracket
Old Dec 23, 2006 | 04:39 PM
djerickd's Avatar
CHILLING SPREE!!!
Default HOW TO: Area1320.com VF30/34/39 IWG bracket
I got this sweet bracket from the boys at Area1320 Subaru and turbo AWD installs and parts I promised them I'd write a review and how-to w/pics so here goes:
IWG Bracket
First remove the 3 8mm bolts from the wastegate mounting bracket and remove the c-clip from the flapper arm:
Now you can remove the internal wastegate actuator, I put this bolt in place so I won't lose it:
and put the c-clip back on the arm so you won't lose it either
Now install the IWG bracket onto the turbo, finger tighten the supplied 13mm bolt onto the bracket, then finger tighten the 2 factory 8mm bolts into the bracket.
Check everything one last time before the final sequence, tighten the 8mm bolts. DO NOT OVERTIGHTEN! tighten the 13mm LAST! Failiure to do so may cause the IWG to leak.
Stand back, have another cold one, and admire your handi-work
Then just run your favorite external wastegate:
SnowMan Tuned
Old Dec 23, 2006 | 04:52 PM
fat angel's Avatar
Secret Squirrel
what does said bracket actually do? do you have it all finished up? shouldn't it be ewg bracket?
Old Dec 23, 2006 | 04:53 PM
djerickd's Avatar
CHILLING SPREE!!!
it holds the IWG shut so you can run EWG
SnowMan Tuned
Old Dec 23, 2006 | 06:06 PM
SnowMann's Avatar
TR Shop Mod
Ouch....that hurts....
SnowMan tuning
Old Dec 23, 2006 | 08:36 PM
djerickd's Avatar
CHILLING SPREE!!!
LOL, the turbosmart is in and it barely clears, it's friggen LOUD!!!
SnowMan Tuned
Old Dec 24, 2006 | 07:24 AM
djerickd's Avatar
CHILLING SPREE!!!
I believe it's around $20
SnowMan Tuned
Old Dec 24, 2006 | 07:37 AM
AvASTi's Avatar
I use a Mad scientist
dj what happened to you last night? i wasnt driving to fast was i?
hahaha sorri i was just screwing around and when i looked back i was like were did dj go................sorry to post off topic...........
symmetry creates balance
balance creates control
Old Mar 16, 2007 | 09:34 PM
KAX's Avatar
KAX
well its about time for me to get my EvoIII. I talked to area1320 about doing a bracket for me for that turbo. They only do the VF30/34/39 brackets at the moment but Ill update if they start making them for the mitsu's.
