Subaru Tech All We'll Drive
Launching tips
Old Aug 11, 2005 | 09:15 AM
  #21 (permalink)
schoellnasty's Avatar
I think its more of the latter, Im just afraid of slipping it too quick and turning into more of a drop. Trying to get it down with the least amount of damage to the tranny that I can. Like I said, Ill talk to/ride with some people at track day and see whats up.
Old Aug 11, 2005 | 09:19 AM
  #22 (permalink)
BrewPuBeaver's Avatar
*Big Schpellar*
you know that when you rn with people the extra weight will throw their times off.
but if you can get some coaching it would be very benificial..... if it is from someone that knows what they are doing. so try and weed through the BS.
Old Aug 11, 2005 | 10:55 AM
  #23 (permalink)
Yeah thats why Im going to ask nicely . I shouldnt need more than one run to get a feel.
Old Aug 15, 2005 | 05:15 PM
  #24 (permalink)
javasti's Avatar
Tampa Stock
I keep bouncing it around 5k and then slip it. Best 60' is 1.71 to date.
Old Aug 16, 2005 | 07:57 AM
  #25 (permalink)
QuickOne's Avatar
It's soooo stock?
If this is what you are doing and can't get below 2.x then check your tire pressure. May need to firm them up a little, maybe around 40-42psi. The re070's are real sticky which can lead to bogg's ville. Sunshine is usually pretty grippy as well. You need some wheel spin or else....blaaaaa.....varoom!
Originally Posted by supaflytiger
Yes another launch thread. So I went to Sunshine tonight. Got 5 runs in and all of my 60' times were well above 2.00. The technique I used was to rev to 4k and blip the throttle between 4-5k. On the second yellow I floored it and stepped off the clutch with the "just stepped in dogshit" method. This was netting me nothing as the car bogged and fell on its face (revs dropped to ~2.5k). I decided I was letting the clutch out too fast and on the next run I slipped it a bit slower. This netted me my best time:
r/t..... .575
60'..... 2.232
1/8.... 9.984
mph... 69.71
The rest of the runs were 2.3-2.4 60' and about 10.2 1/8. Traps were consistent at 69.xx. So Im about 4 tenths off of a good 60', 9 tenths off of a good 1/8th, and 5mph off of a good trap. I bogged every run, so Im wondering what the cure is for that. I know its a common problem when first dragging the car, but what did you guys do different to get rid of it?
Old Aug 16, 2005 | 08:47 AM
  #26 (permalink)
Well I dont have to worry about the stickyness of the re070s cause I dont have an sti. I just need to practice more really.
Old Aug 16, 2005 | 09:28 AM
  #27 (permalink)
QuickOne's Avatar
It's soooo stock?
Or what ever tires you are running....same still applies.
Old Aug 16, 2005 | 09:58 AM
  #28 (permalink)
Yeah I bumped them up to 40 all the way around at BMP on saturday, but it didnt seem to help. Then again I did screw the pooch on 2 of my 5 launches, so I didnt really have them up that high for enough runs to tell if they were helping. Like I said practice practice practice.
Old Aug 16, 2005 | 11:27 AM
  #29 (permalink)
BoosTedEj25's Avatar
oneslowwrx
well my AEM EMS has a option that untill i reach 10 mph it will only let me rev up till 5,500rpm so i just floor it and wait untill i feel the clutch grab and i just dup it after that. It works for me, before the EMS i would just rev it up till 4k and wen the light turn green i would punch it and just drop the clutch, my best 60ft has been a 1.6
