Subaru Tech All We'll Drive
Wtf?!
Old Jul 22, 2005 | 02:11 PM
  #21 (permalink)
lstepnio's Avatar
1337 H4x0r
Originally Posted by Balboa
The wire for the front O2 sensor is still plugged into the O2 sensor, which is in place.
If it was a CEL fix for the rear O2 sensor, it was a failed attempt.... Took out the oxygen sensor today and found there is a hole burned through the top -- switch sensor with my dad's '05 WRX for our long trip tonight and tomorrow.
I'd take a look at the EGT sensor. The passenger of the vehicle a wire with some type of heat sheilding running to the uppipe below the turbo. If I recall correctly the sensor plugs in below that little plastic cover on the passenger side. You won't be able to easily see the sensor but you should be able to feel around for it from the top when you trace the cable. I removed mine and replace with a bolt and resistor.
-luke [www.majjix.com]
Old Jul 23, 2005 | 12:01 PM
  #22 (permalink)
Black05wrx's Avatar
Evan, you have to remember that Gene wasnt the first owner of that car, so it might have been from the previous owner. Either way its not cool.
Old Jul 23, 2005 | 01:56 PM
  #24 (permalink)
SnowMann's Avatar
TR Shop Mod
Originally Posted by lstepnio
I'd put couple bucks on a failed EGT proble or one that kept backing out and was removed. Both situations are very-very-very common. The EGT probe is only there to prevent a total meltdown of the factory uppipe cat. The forced induction Subaru's that don't have an uppipe (2.5L STi, Forester XT, not sure about the LGT) don't have the EGT sensor.
The other good guess is rear O2 sensor "fix", which is common for anyone with an aftermarket exhaust.
The Forester XT does come with a EGT sensor on the catted up-pipe.
SnowMan tuning
Old Jul 23, 2005 | 02:05 PM
  #25 (permalink)
QuickOne's Avatar
It's soooo stock?
Dude, if you bought that car from a dealer I would think you should have some recourse.
Old Jul 25, 2005 | 04:32 AM
  #26 (permalink)
Bill's Avatar
Livin' in Seattle
If I had to make a guess I'd say the wire runs the signal for an O2 sensor. O2 sensor wires are usually shielded wires (the unsheathed wire you see in the pic is wrapped around a sheathed wire) to prevent signal distortion. The yellow/black wire connected to the shield wire (bare wire) is most likely a ground (pretty common color scheme for ground) and it's being used to ground the shield wire. If this is the case, it's really not that uncommon to see a setup like this though not exactly kosher in some cases. The previous owner was probably trying to run an A/F sensor or nullify an O2 sensor. Is it pretty? Hell no. Is an electrical fire going to break out now? Nope. Still though, might want to tidy it up a bit as a loose shield like that could cause signal issues.
Found this today while installing a turbo timer in my car:
Didn't mess with it because the car runs fine...just wondering what the FUCK the previous owner did?
Gene Jones I hate you!
Old Jul 25, 2005 | 05:07 AM
  #27 (permalink)
DubtecV2's Avatar
...in da hause!!!
I'm going to take a closer took at it on tuesday...Might anyone know where I can print out a pinout for a 2004 STi?
Also, anyone know what the white connector is (right of wire mess)? It's covered with electrical tape...
Old Jul 25, 2005 | 05:11 AM
  #28 (permalink)
Bill's Avatar
Livin' in Seattle
There is a factory manual download floating around on the web. When I picked up my '05 I downloaded the '04 manual from a guy on this site. Maybe he'll offer to let you download it as well. If not, just google for it.
As for the white connector, no clue. Perhaps it's some type of electrical tape storage zone?
Old Jul 25, 2005 | 05:20 AM
  #29 (permalink)
DubtecV2's Avatar
...in da hause!!!
Lol, I hope I don't find much more 'storage'
Google, here I come!
Old Jul 25, 2005 | 08:08 AM
  #30 (permalink)
lstepnio's Avatar
1337 H4x0r
I posted the link to the wire diagram you're looking for already.
http://www.ravensblade-impreza.com/m...04_STi_ECU.pdf
