Subaru Tech All We'll Drive
mah paint!!!
Old May 10, 2005 | 12:34 PM
slows10's Avatar
Default mah paint!!!
Well yesterday I pulled into the garage and my sister had moved her bike over a little. Need less to say I rubbed the tire causing the bike to fall on my car. So my question is what is the best way to minimize the appearance of this scratch? will just waxing work and if so what is best?
Old May 10, 2005 | 12:39 PM
davcivic's Avatar
El Mas turboso
If it is superficial, wet sand the clear and buff it, it'll come right out, if not you have to repaint the whole panel.
2002 Subaru WRX
1988 Honda Civic Hatch
Old May 10, 2005 | 12:45 PM
slows10's Avatar
what is do you mean by superficial
Old May 10, 2005 | 01:16 PM
Frankie Figs's Avatar
Too Much is ALMOST Enough
Superfcial = Minor. Sorry to hear about that
Old May 10, 2005 | 01:17 PM
StiGuy's Avatar
4 doors & 6 on the floor
Pronunciation Key (spr-fshl)
adj.
  1. Of, affecting, or being on or near the surface: a superficial wound.
  2. Concerned with or comprehending only what is apparent or obvious; shallow.
  3. Apparent rather than actual or substantial: a superficial resemblance.
  4. Trivial; insignificant: made only a few superficial changes in the manuscript.
Old May 10, 2005 | 02:38 PM
QuickOne's Avatar
It's soooo stock?
adj.
NICE! ^^
Old May 10, 2005 | 06:29 PM
davcivic's Avatar
El Mas turboso
too funny
2002 Subaru WRX
Old May 12, 2005 | 04:33 AM
Bill's Avatar
Livin' in Seattle
You might want to ignore the above comments about wet sanding until you figure out the extent of the damage. If the scratching is minor (ie: not down to the primer or bare metal) then a polishing compound will get it out easily enough. There are quite a few polishes on the market that can be applied by hand and yield good results. If you have access to an orbital buffer then the job becomes even easier. Now if the scratching is major (ie: down to the primer or bare metal) no amount of polishing compound is going to help you. You'll need to grab some touch up paint and fill the scratches. Then you'll need to go ahead and wet sand the paint flat and finish up with a polish, buff, and wax. If you're going to do this yourself I'd suggest reading up on the following site: www.autopia.org
Old May 12, 2005 | 06:11 AM
slows10's Avatar
hey thanks for the info bill
Old May 12, 2005 | 07:19 PM
smooth_ej20's Avatar
try meguires scratch x. I slipped popping out a panel in the rear and scratched my doorjamb. Scratch-x worked like a charm.
focheezy
Apr 9, 2005 02:01 PM
Skyline Driver 5
Feb 20, 2005 11:45 PM
Abstractlude
Feb 11, 2004 07:16 PM
Cronic
Aug 16, 2003 12:57 PM
