Subaru Tech All We'll Drive
heatwrapped downpipe. STi not happy
Old Feb 15, 2005 | 01:30 PM
I'm Slow's Avatar
I'm Slow
Since the gasket is after the turbo........it will not affect your boost, even if it was leaking. I think the downpipe is not the problem, maybe it is because it is hot now as opposed to the past couple of days being fairly cool weather.
Old Feb 15, 2005 | 03:51 PM
I'm Slow's Avatar
I'm Slow
The only way to be certain is to try it, but I am almost positive that your downpipe isn't the problem with your boost. It may have been weather related. Do you have a MBC or EBC? The heat wrap would only make a difference with how fast the air can move throught the downpipe, which may affect HP numbers but not the amount of boost you are able to hit. But, again trial and error is the only way to be ABSOLUTELY certain. If your anything like me, you are probably peeling off heat wrap ( an absolute bitch to do!) to try and gain back some boost. Boost is made before the turbo and at the turbo......so boost lost cannot be caused by parts after the turbo. Do you have a blow off valve?? with the change in back pressure a BOV could be bleeding off boost if not adjusted properly. Just throwing possibilities out there!
Old Feb 15, 2005 | 05:06 PM
Apexi wrx's Avatar
The NExt Brian O' Conner
it could be something with your ecutek after doing this
Vroommm psshhh
Old Feb 15, 2005 | 07:29 PM
I'm Slow's Avatar
I'm Slow
Ok, thanks to Apexi wrx's comment I think I know why this has happened. The o2 sensor could be registering higher EGT's and therefore the ECU is pulling boost in order to keep the EGT's down to what is considered ideal in the tune parameters.
