Need help ls-vtec build - need help ls-vtec build *see*
Hey tr, i finally finish my ls-vtec swap and droped it in my ek hatch. Everything is connected it's on a p28. Single cam harness. Also built in internals for high compression. I turn it on, but won't rev more than 2k
sadly idk wat to do injectors are working perfect also all the sensors, tps,map,ect.
I notice it rev redline wen i use starting fluid but with just normal it won't pass 2k rpm. Please help!
Contact me : 813-802-1429 willing to pay. Maybe some of ya encounter this problem!
Note: My most accurate guess might be the wiring harness since it's from a d-series.
If so i wtb b-series harness that would work with my ls-vtec
probly, in limp mode I es reading a tread about the same ecu but didn't understand quite. If it is on limp mode what should be done ? The ecu works fine, because I tryed it on another civic and it rev successfuly but in mines won't pass 2k
That's what I thought at first that not enough fuel was coming in, but the pressure on the fuel has pretty good force. I also been thinkin if the distributor is bad but i bought it brand new and the car starts fine it just dosent rev pass 2k
