The Projects Watch out in this hood ! Current And Past Ford Project Topics Only.
My 85 Coupe Project.....
Old Apr 25, 2009 | 12:31 PM
  #221 (permalink)
franktf's Avatar
I got the valve cover and tube back from the welder yesterday afternoon..... Today I put the hole in the valve cover for the breather and put it on the car..... I forgot about the boost reference line for the FPR, so I'll have to order the fittings for that..... Also put the tube on along with the blow-off valve/line, waste gate line..... I forgot about the boost reference line for the FPR, so I'l have to order the fittings for that..... I mounted the MSD/MAP sensor and did all the under hood wiring for it.....
Tomorrow I need to get the dist together and see how the plug wires fit, they were on the old combo which had the early firing order..... So I need to rearrange them and see if they will work for the HO firing order, we shall see.....
Pic's from today's progress.....
Old Apr 26, 2009 | 01:24 PM
  #222 (permalink)
franktf's Avatar
I put some oil in it first thing this morning and primmed the oil pump, pressure looks good..... Then I rebuilt my Ford Duraspsrk Dist and installed it(new pick-up coil, reluctor, removed the vacuum advance and locked out the mecnanical advance)..... The I rearranged the plug wires for the HO firing order, and was able to get them to work without having to cut or modify any of them..... Also put the air filter on..... I just ordered my wideband, the last piece of the puzzle so I can get it running..... Once it gets here I can put it in and finish up the wiring under the dash again.....
Pic's.....
Old Apr 26, 2009 | 07:33 PM
  #223 (permalink)
LLFordMan's Avatar
WIRE IT HOT!
Frank, your coupe looks awesome. I like how you dressed all of your wiring with zip ties. It reminds me a lot of when I used to bundle all of the cabling for building communications equipment in cell towers.
Sounds like you will be firing it up soon. Good luck with the first fire!
Old Apr 26, 2009 | 09:11 PM
  #224 (permalink)
Stealth Mode's Avatar
Still CREEPIN
frank, one question, how did u prime it?
TurboRAM Member #5
24psi & Stable
GET SOME
Old Apr 26, 2009 | 11:11 PM
  #225 (permalink)
GNs-r-slow's Avatar
Bondsman
primer...duh!!!
Old Apr 27, 2009 | 02:06 AM
  #226 (permalink)
460 TZILLA's Avatar
THROTTLE STEER
Car is looking sharp! keep the pics coming..Nice work
Talk softly but Drive a big block
Old Apr 28, 2009 | 02:13 AM
  #227 (permalink)
GNs-r-slow's Avatar
Bondsman
Interested in the console delete dealio. What did you do there Frank?
Old Apr 28, 2009 | 03:32 AM
  #228 (permalink)
franktf's Avatar
I made an aluminum piece that bolts in place of the console, I made it back when I had a job I had access to sheers, brake presses and suck to aid in the manuplation of sheet metal.....
Old Apr 28, 2009 | 03:35 AM
  #229 (permalink)
franktf's Avatar
Electric drill and one of these..... Moroso 62210 - Moroso Oil Pump Primers
Old Apr 28, 2009 | 02:06 PM
  #230 (permalink)
franktf's Avatar
Tore apart most of the dash today so I could do some wiring..... Got alot of the wiring rearranged..... The O2 alert will be here tomorrow along with the rest of the fittings I need to make the boost reference line for the FPR..... I'll have to make a mount for the wideband, finish wiring, put the dash back together, put the pass seat back in and make the reference line..... Then it should be ready to start.....
I hate to see it but here's some pic's of the dash apart for wiring.....
