The Projects Watch out in this hood ! Current And Past Ford Project Topics Only.
My 85 Coupe Project.....
Old Dec 29, 2008 | 02:24 PM
  #121 (permalink)
franktf's Avatar
I messed around with that bracket for a couple hours today and just was not happy with how the down pipe would be routed, so I ditched that somebitch.....
I am going to just mount the turbo on the driver side header instead..... This will make everything work out for the best..... I got started on building the driver side header, so I atleast think I made some progress today..... The front 2 tubes are tacked into the header flange and welded to the collector star I made..... It was also a pain getting the tube squared up to fit the header flange properly..... I am going to try and get the rest of the ds header done tomorrow.....
Here's what I did today.....
Old Dec 29, 2008 | 03:12 PM
  #122 (permalink)
**CHRIS**'s Avatar
Called the amba lamps
Nice welding Frank!
She's gonna be a beast when she's done.
Old Dec 30, 2008 | 11:09 AM
  #123 (permalink)
franktf's Avatar
Thanks.....
All four tubes are now in the DS header and it is completely welded..... It just needs a collector put on it now...... But after I welded the tubes to the inside of the flange I bollted it back up to the head and welded the outside top and bottom, then I leaft it bolted up so it could cool completely too pretvent warping.....
Here's a few pic's of todays progress.....
Old Dec 30, 2008 | 11:17 AM
  #124 (permalink)
MiDiablo's Avatar
Damn man, great job!
Old Dec 30, 2008 | 12:45 PM
  #125 (permalink)
GNs-r-slow's Avatar
Bondsman
Frank is a fabbin mofo! I'll take a set
Old Dec 30, 2008 | 07:36 PM
  #126 (permalink)
Stealth Mode's Avatar
Still CREEPIN
is this the windsor engine?
TurboRAM Member #5
24psi & Stable
GET SOME
Old Dec 31, 2008 | 10:23 PM
  #127 (permalink)
Tiffiny's Avatar
I can fix your bullshit
badddassssss
Old Jan 1, 2009 | 01:16 PM
  #128 (permalink)
franktf's Avatar
Thanks.....
It's a 302 windsor.....
The flange didn't warp at all..... I cleaned up the weld in all the openings of the flange and the four tubes where the collector goes..... Then I fitted the collector and welded to the header..... The next thing I did was fit the turbo flange to a piece of 3" pipe, and weld it inside and out..... After welding it I bolted it the the turbine housing while still hot to prevent it from warping.....
Progress pic's.....
Old Jan 1, 2009 | 02:21 PM
  #129 (permalink)
79 pace car's Avatar
thinks TR sucks ass now
damn Frank, you are the man. is there anything you can't do? can't wait to see it done.
this site sucks balls now. fuck tampa racing, not coming back.
Old Jan 1, 2009 | 02:25 PM
  #130 (permalink)
864I'DCaprI's Avatar
doowutchyalike
Great work Frank
(C)lassic (A)merican (P)erformance (R)acing (I)nspired
