GROUND UP EF hatch build.
Old Jan 2, 2012 | 12:44 AM
  #221 (permalink)
Paulino's Avatar
Not harsh, just truthful
Man that pwrdjdm bar covers up the pretty itb's!
Old Jan 2, 2012 | 05:20 PM
  #222 (permalink)
tai mishuu911's Avatar
rut roh
Yeah, I don't think it will even clear the fuel rail. So up for sale it goes.
N/A GSR on its way.
StricKly MT 727-510-6301
WIREWORX 407 388-5809
Old Jan 3, 2012 | 01:29 AM
  #223 (permalink)
Paulino's Avatar
Pm sent.
Old Jan 8, 2012 | 12:50 PM
  #224 (permalink)
rut roh
Got in a little work today.
Need to get misc nuts and bolts still
Rear coilovers installed along with camber kit and lca's
Also test fit the wheel on for shits and giggles. Going to run 8-10mm spacers all they way around
N/A GSR on its way.
Old Jan 15, 2012 | 06:14 AM
  #225 (permalink)
jdmstefan's Avatar
looking good dude!
Old Jan 15, 2012 | 04:52 PM
  #226 (permalink)
lilmike13's Avatar
SAVE THE SOHC!
loven it cant wait to see it on the road
93 del sol si (project)
88 honda cvic ef (daily driver)
hit me up on fb ( www.facebook.com/stewartracing13 )
TR "Old Skool EF" Member #166
Old Jan 16, 2012 | 04:32 PM
  #227 (permalink)
rut roh
Thanks guys. Unfortunately didn't get to work on it as much as I hoped to this weekend. Unexpectedly had to drive up to Gainesville to help my friend pull his motor.
Ended up putting it in his apartment until we could bring it to the shop.
and his nice little turbo setup...
However, I did get to putting the front suspension back on. Courtesy of Strictly MT, fresh hardened rubber bushings in the LCA,s and new ARP wheel studs and Honda OEM wheel bearings along with new lower balljoints installed. Also installed the Skunk2 upper control arms.
N/A GSR on its way.
Old Jan 17, 2012 | 04:31 AM
  #228 (permalink)
integra's Avatar
90% grind 10% sleep
Good job Chris..
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
Originally Posted by THE_ONE
Old Jan 17, 2012 | 05:16 AM
  #229 (permalink)
jdmstefan's Avatar
looking good chris will have to see it soon!
Old Jan 22, 2012 | 05:35 PM
  #230 (permalink)
rut roh
Finally got a plug for my TP sensor on the ITB's so I did some wiring work today. Removed some misc plugs from the engine harness.
I hope this bundle of wires doesn't scared people off.
Got it a little bit more organized and then went to installing my Type R Engine Stiffner.
I'll most likely finish up this wiring this weekend unless I run back up to Gainesville to help my friend put his motor back in. Shifter should also be installed along with clutch system. Full hydro conversion. Order some tires, race fuel, and start her up.
N/A GSR on its way.
