GROUND UP EF hatch build.
Old Dec 28, 2011 | 12:35 PM
  #211 (permalink)
tai mishuu911's Avatar
rut roh
Originally Posted by integra
nothing important...LOL..
I know, Like what sensors aren't important. You told me awhile ago but I guess I never wrote it down.
Originally Posted by LATINO HONDA
keep up the build cant wait to see my old ef finished
Thanks man. Yeah, I bought the damn shell forever ago!
N/A GSR on its way.
StricKly MT 727-510-6301
WIREWORX 407 388-5809
Old Dec 28, 2011 | 03:06 PM
  #212 (permalink)
rut roh
Gotta stay up to date.
Installed the radiator today along with the Samco hoses to hold it in place for the most part. I still have to make a bracket to hold it. Also had to cut the upper hose about half an inch or so since the radiator sits closer mounted on the FR traction bar.
Also started routing a little bit of the wiring.
N/A GSR on its way.
Old Dec 28, 2011 | 08:32 PM
  #213 (permalink)
MikeyL513's Avatar
BOOSTIN
Looks great chris
Old Dec 31, 2011 | 10:08 AM
  #214 (permalink)
quietflight6787's Avatar
Awesome update I check this thread all the time looking to see!
Old Jan 1, 2012 | 02:43 PM
  #215 (permalink)
rut roh
Thanks.
Unfortunately didn't get too much done this weekend. I still have to finish the harness and get some starter bolts and then it should be ready to start...save for getting some fuel.
Got the header on after having to bore out the ports on the manifold gasket.
Set the PWJdm Strut tower in place but I don't think it's going to work. It doesn't clear my fuel rail.
Got the steering setup put on to help maneuver the car when I roll it in and out of the garage.
That's about it. It's going on jack stands to get my extended wheel studs and new wheel bearings installed, along with new hardened rubber bushings for the front LCA's
N/A GSR on its way.
Old Jan 1, 2012 | 05:45 PM
  #216 (permalink)
integra's Avatar
90% grind 10% sleep
I got starter bolts...LMK you can have them,,,
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
Originally Posted by THE_ONE
Old Jan 1, 2012 | 05:47 PM
  #217 (permalink)
rut roh
I keep forgetting to text you. I was going to see when I could come by the shop to get the wheel studs/wheel bearings and front control arm bushings done.
N/A GSR on its way.
Old Jan 1, 2012 | 05:57 PM
  #218 (permalink)
integra's Avatar
90% grind 10% sleep
Just call or text...I been busy,but I told you I would make time for your.
Old Jan 1, 2012 | 06:09 PM
  #219 (permalink)
rut roh
Will do. Hopefully sometime this week.
N/A GSR on its way.
Old Jan 1, 2012 | 07:39 PM
  #220 (permalink)
LATINO HONDA's Avatar
BALLER
The other day i was speaking to one of my friend and said , what the hell did i do with that red ef i didn't remember but then i saw your build and said that's where it went, dam its been that long I've had so many Honda's and this is the only one I've forgot about It took me a good while to remember.Im glad to see its in good hands. keep up the good work and show many pictures.
