Sponsored by: CARiD
where does the ext waste gate mount.
Old Mar 31, 2003 | 12:11 PM
Trip's Avatar
Dramatic Lemur
You can mount it off one exhaust port on the mani, or in the centerof the mani, before the turbo, or on the side of the turbo, wherever exhaust can escape to limit pressure....
Added: This turbo's turbine housing is like the internally wastegated t3 setup's, but this one has that removed and the area where the internal waste gat would dump into the down pipe is used to feed into an external w/g. Then a different gasket is used to seperate the downpipe and w/g outlet. Notice the design of the downpipe in you kit picture..
"Never attribute to malice that which can be adequately explained by stupidity."
AIM: TurboedTrip
Old Mar 31, 2003 | 12:31 PM
buck19's Avatar
Forever Broke Nissan
yep i wish he was still in business. his kits where very nice putting out an extra 75 hp on his non i/c with the old t25.
his "new" kits has the t3/t04 and you could get either a liquid or air to air ic for a possible 115-130 more hp at 5-7psi. but has no dyno numbers for the new kits.
If you have three quarters, four dimes, and four pennies, you have $1.19. You also have the largest amount of money in coins without being able to make change for a dollar.
Old Mar 31, 2003 | 02:07 PM
Trip's Avatar
Dramatic Lemur
Who was he??
AIM: TurboedTrip
Old Mar 31, 2003 | 02:14 PM
buck19's Avatar
tom coleman at www.ludespeed.com out of orlando
