Sponsored by: CARiD
Spray and High compression
Old Dec 5, 2002 | 02:39 PM
Strongest Man In The World's Avatar
Embrace the Hate
thats what i thought but i wasnt gonna tell him what to do on his setup :shrug:
CombatFitnessBlog.com
Click ^^ to receive the controversial Ebook "Maximize Your PT" for FREE
People fear what they don't understand, hate what they can't conquer. Guess it's just the fury of man!
Who are the Hardcore lifters?? StrengthCamp RyanMagin.com
Old Dec 6, 2002 | 05:03 PM
RONIN's Avatar
Tetris on a stick
i ran 8 psi on 10.5 comp, with forged bottom, and was looking to add n2o before i joined the dark side. boost doesn't not like high comp, you just can't run the extreme levels like you could with lower comp. on my plus side i had power when not under boost also. the mini-me mentioned also has some other tricks up his sleeve.
i would worry about a 100 shot on a stock parts with comp, one small mistake in the a/f is going to burn you.
Eat a live toad every morning, and that will be the worst thing to happen every day.
Old Dec 6, 2002 | 05:38 PM
0HP930's Avatar
Guest
Originally posted by "crx89si"
thier is a guy in bredenton running the y8 mini me 11.1:1 comp and runing 11psi on a jrsc it runs good. it works good because of the flat a6 pistions and the smaller cc' chamber on the y8 head.
I got to say I'm pretty skeptical of anyone getting away with that much boost on top of that much compression.
Compression + boost has its limits no matter what the piston geometry or chamber design is like.
Old Dec 6, 2002 | 05:50 PM
TampaTraps's Avatar
get big or die trying!!
yeah it's sounds weird but pm bert-o he works with the guy at bradention honda. i just sold him a part and saw the car and know a y8 head on a a6 bottom is 11.1:1comp. so ask him
Old Dec 6, 2002 | 10:59 PM
Matt Vassallo's Avatar
lifelong learner
last time i checked i believe seeker one steve had forged internals, but i could be worng.
rest in peace tim.
Old Dec 7, 2002 | 08:45 AM
  #17 (permalink)
BERT-O's Avatar
yO!
Nope, its doable and can be realiable. As long as your air/fuel mixture is correct, anything is possible. Hint, Hint .....engine management.Hell, I've seen B-series motor running 12.5 comp or higher on pump gas.
Old Dec 7, 2002 | 08:54 AM
  #18 (permalink)
BERT-O's Avatar
yO!
Yes, he did rebuild it for more boost and to run a bigger Nos jet.
However, he didn't have no problem running with the same set-up, But he is running a engine management to correct his air/fuel ratio in order for hime to generate more boost.
His setup will take out B-series guys with or without forced induction. His mods quite sleeper with his SOHC mini me.
Old Dec 7, 2002 | 07:18 PM
  #19 (permalink)
SEEKERone's Avatar
Trialed for Treason
Default SEEKERone speaks
not that this has everything to do with the inntial topic but since i was mentioned i would like to set the record straight.
i have run a mini-me setup (A6 block-Y8 head 11.0-1compression) with 11psi JRSC boost with 25ish nitrous shot...this dynoed to 189hp and 174trq. this WAS with stock pistons and rods. this configuration was damaged by running an extended high speed, full boost and juice fifth gear run(speedo was WAY buried). stock cast pistons were subjected to severe stress and reponded by cracking at the ring lands. engine was reassembled using forged pistons and rods with slightly lower compression(approximately 10.3-1) and fed a slightly larger dose of nitrous. this configuration has dynoed at 200hp and 165trq. anyone who knows my car will verify the fact that it is no race car being complete interior plus the usual 1/2 ton of misc. junk floating around in the back. also being a sohc means the the best Dseries trans is equal the the worst Bseries trans. as far as being a threat i can hold my own.
<rant mode off> with all that being said can what was intially asked be done...quite possibly. but the most important thing is tuning. don't think that you can just bolt a few pieces on, add the juice and be ready to go. tuning is the key to increasing power by the amount you want and still retaining some sense of drivability and reliability. as other have said start smaller and work up from there. a standalone is most helpful (work great for me) but is worthless if not tuned with the help of someone who knows the path.
Old Dec 10, 2002 | 03:42 PM
  #20 (permalink)
RONIN's Avatar
Tetris on a stick
hey steve, was that on the squeeze or just the mechanical stuff?
