Sponsored by: CARiD
Boost loss.
Old Nov 17, 2002 | 07:41 AM
BoostedRS's Avatar
I can freeze time
One of the bigger thing to look for, especially in a HUGE front mount, is efficiency. Chances are, bigger intercooler = more pressure drop. That is given your piping is right, and your couplers are tighter than a virgin in prom night.
Olympus Evolt E-510, E-520, E-30 x 2
11-22mm f/2.8-3.5 Zuiko Digital
14-54mm f/2.8-3.5 Zuiko Digital
35-100mm f/2 Zuiko Digital
50-200mm f/2.8-3.5 ED SWD Zuiko Digital
Cybersync wireless trigger
FL-36R, FL-50R, Metz-48, and Vivitar 285HV x 3
Old Nov 17, 2002 | 11:19 AM
BlackZ28's Avatar
ppssshsshhhhhhh
when u add more space u get a pressure drop. u could also be losing pressure if u didnt hook it up right. check all the hoses and clamps to make sure. how much bigger is ur new IC?
Old Nov 18, 2002 | 04:47 AM
0HP930's Avatar
Guest
Just adjust your boost controller to make up for the pressure difference and all will be well.
Old Nov 24, 2002 | 12:42 PM
drift's Avatar
Hatorator
but the longer you make the vacuum line, the less responsive the wastegate will become.
don't exceed 3 feet on that line. if you go over 3 feet, you may as well adjust the wastegate instead to be more reliable.
1997 Prelude, H23A1 VTEC
Items for sale:
H22/23 block and all internal parts
4 5th gen Prelude wheels, 16x6.5, 5x114.3mm bolt pattern
More stuff for sale:
https://www.tamparacing.com/forums/showthread.php?s=&postid=472993#post472993
