Sponsored by: CARiD
Boost loss.
Old Nov 25, 2002 | 03:01 PM
drift's Avatar
Hatorator
Originally posted by "FearThe4Doors"
btw, larger volume in the IC and longer IC pipes wont cause a loss in boost, only in spool up time.
mismatched volumes within the intake tract will cause pressure drop due to a turbo's fixed amount of flow.
volume doesnt change, but due to changing restrictions in an improperly set up turbo system will change pressure readings.
compare it with a 4" hose and a 1" garden hose both flowing the same amount of water... the 1" will have more pressure due to more restriction, but in the end still will flow the same fixed amount of water for both hoses.
1997 Prelude, H23A1 VTEC
Items for sale:
H22/23 block and all internal parts
4 5th gen Prelude wheels, 16x6.5, 5x114.3mm bolt pattern
More stuff for sale:
https://www.tamparacing.com/forums/showthread.php?s=&postid=472993#post472993
Old Nov 27, 2002 | 01:41 AM
Durdan's Avatar
No Ants Drift Member
Didn't work, still only have 5psi I moved the line from the compressor to the BOV. I'll try the intake manifold.
dont attach it to the BOV... you can tee off the FPR to the wastegate.. that way the wastegate actually sees true manifold pressure. i would just check to make sure that all your fittings are good and tight.. even of they dont blow off, they can still seep out boost
RIP Tim. i miss you, buddy
