Sponsored by: CARiD
MAF installed in Coldpipe????
Old Jul 13, 2004 | 10:18 PM
dan's Avatar
dan
Get the fuck off my lawn
s14's came with a plastic MAFs that was ~2.6" ID.
that metal one is for an s13, or an sr20det.
Old Jul 14, 2004 | 04:48 AM
TNathe's Avatar
Oh yeah, so if I run 2.5" cold pipe will the temperatures be too hot and the plastic MAF be too weak to mount it into cold pipe?
Thanks again.
Old Jul 14, 2004 | 03:26 PM
dan's Avatar
dan
on freshalloy, my friend brian (he runs www.ka24development.com) originally used a hacked maf with a ~2.75" ID pipe on his non-intercooled setup and ran 4psi on a blow-through setup. he probably used almost a whole roll of electrical tape and i think some jbweld or silicone, but it worked. after he got his FMIC kit, he went to a draw through setup because we doubted it would hold more than 4 psi for very long. he has since redesigned it and it has a different pipe with shims to adjust the diameter (you can put a shim in and reduce the diameter thus making it richer).
i am buying his setup since he is on 50lb/cobra maf/jwt ecu, so ill get some pics once i get it.
