Sponsored by: CARiD
Bov position theory
Old Oct 26, 2003 | 12:56 PM
Jonas's Avatar
Default Bov position theory
placement... near turbo, or near throttle body?? and why... are there any specific turbo applications or set up in which you would want the bov to be near turbo or tb...??
Jonas
Old Oct 26, 2003 | 02:29 PM
Sneakin Deacon's Avatar
PSSHHH x2
i wouldnt know much on the subject, but i think anywhere on the intake piping would be sufficient as pressure (i think) would be evenly distributed throughout the piping. i do know people who flow alot of air and have to use 2 BOV's to prevent compressor surge
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
Old Oct 26, 2003 | 02:35 PM
Ep41382's Avatar
TR Balla Donor Supreme
i believe your correct Kenny, all the IC piping has the same amount of pressure no matter what the distance form the turbo is... therefore it wouldnt matter
Eric
AIM: Ep41382
Old Oct 26, 2003 | 03:46 PM
flubyux2's Avatar
Elitist Supra Asshole :)
well... i think it would be better to place the BOV's near the TB... that way the air flowing inside of the pipes and intercooler is all still moving and ready to surge forward when the BOV closes and the TB opens.
If you place the BOV at the compressor outlet or near it... that means when the throttle closes, the whole column of air inside the Pipes and IC AFTER the bov stalls inside the pipes, and there is a certain amount of resistance that the turbo has to overcome to get that slug of air moving again when the throttle opens and the bov closes... i mean, its proportional to the weight of the air... but still, its inertia that the turbo has to overcome and can easily be alleviated if the Bov was positioned near the TB.
Im fixin to install both my BOV's on my supra by the TB, if that helps any.
Remember: An object in motion tends to stay in motion (air flowing thru your IC and pipes venting right before the TB)
and
An object at rest tends to stay at rest (air stalled inside your IC and pipes due to the BOV venting at the compressor outlet)
Old Oct 26, 2003 | 04:20 PM
flubyux2's Avatar
actually... 17 psi w/ no bov and mad compressor surge is enough to make my pee pee pack up his balls and leave.
and if the BOV is right near the TB, the pressure wave or shock wave wouldnt go any further than the BOV... the air coming from the turbo, thru the pipes and the IC could keep moving just as if the TB was open yet be diverted out the BOV... so the pressure/shock wave would not travel all the way back thru the pipes and IC.
Old Oct 26, 2003 | 05:41 PM
Slash's Avatar
THE HAMMER
I believe enthalpy will chime in with his close as possible to the throttlebody stuffs.. least i think thats his idea. Hes got some 10 page explanation i'm sure...
If i'm wrong, oh well.
I dont feel like a sig today.
Old Oct 26, 2003 | 08:29 PM
TurboJZA70's Avatar
Old School "Turbo" dude
im all for close to tb. like to keep that air flowing in the same direction all the time. also the pressure is not always the same at diffrent parts of the system. when the plate closes theres a nice prssure wave that runs back down the pipe as all the air trys to turn around and exit the system where ever it can. its a good idea to put the exit near where it starts. near the tb.
Buy a TR email address Here
Old Oct 26, 2003 | 09:00 PM
dan's Avatar
dan
Get the fuck off my lawn
i'll be damned if there is any difference, until i see some kind of dyno or technical results. half the turbo cars here arent crazy high power where its gonna make a difference anyways.
