Paint, Body, and Detailing Discussions on how to keep your ride clean, shiny, and straight
Elva’s new clutch system would require some fabrication
Old Nov 28, 2024 | 02:50 PM
Default Elva’s new clutch system would require some fabrication
Well, our Elva’s new clutch system would require some fabrication
Update by Tim Suddard to the Elva Mk VI project car
Oct 8, 2024 | Elva, Restoration, Elva Mk VI
So, our new clutch hydraulic system? We ran into a snag.
You see, the ideal place for the clutch slave cylinder mount on the transaxle was already occupied by the transmission mount.
We decided that the simplest way to combine the two would be to just move the transmission mount over about an inch and a half.
Sure, we would have to slightly move the mounts on the frame, but almost nobody would be able to tell. We cut, drilled and trimmed our new mounts for our Elva Mk VI’s transmission before painting them with VHT black epoxy.
We’ll know how well this all works when we get deeper into assembly.
Previous
Constructing our Elva’s clutch linkage using off-the-shelf parts
All updates
Next
How do you wire a car when no harness exists?
Nov 28, 2024 02:44 PM
Finkey
Nissan/Infiniti Tech
8
Apr 27, 2010 06:35 PM
Rotary7
Oct 11, 2006 01:59 AM
HPNOTIQracing
Apr 7, 2006 01:12 PM
Cronic
Mar 29, 2003 07:52 PM
