s14 no fuel problem
Old Jun 3, 2012 | 05:44 PM
Trevor_Dirck's Avatar
Default s14 no fuel problem
i have a 95 s14 i just finished up a blacktop swap in. trying to start the car and turns over but wont start. i cant hear the new walbro 255 lph priming and plugs dont smell like gas. so im assuming its not getting fuel. ive checked fuse and relay both are fine. everything worked before swap any suggestions that i can try or check?
Old Jun 3, 2012 | 06:11 PM
Super Coupe's Avatar
Old school TR member
Check the fuel pump pin on the ECU with a multimeter when key is turned to the on position. See if you get a reading....
Hardwire the fuel pump (use inline fuse) and see if it primes. If so just have someone hold the wires to the battery while you turn the car on.
Old Jun 3, 2012 | 07:35 PM
Empire's Avatar
buildin' it
yeah, you would hear that walboro spinning.
loud little fuckers.
once you test the pump itself, go back over all of your wiring.
it is probably something dumb that was just overlooked.
example, was the car an automatic before the swap and did you swap to a 5spd? did you remember to wiring up the neutral safety switch?
Old Jun 4, 2012 | 07:22 AM
thanks for the advice ill check the pump when i get home from work today. and no it was manual from factory ill go back over the wiring for the pump too
Old Jun 4, 2012 | 07:52 AM
BABILLARACING's Avatar
did you wire the pump backward?
My shit still slow
618 whp 492 ft/lbs at 22 psi (Low Boost)on pump gas ,
stock block ,more power coming soon ,stay tuned
Tuned by Alpha @ Induction Performance
Old Jun 4, 2012 | 08:50 AM
I don't think it would matter. Lol. Mine ran with it wired backwards,walbro. It was really high pitched wired backwards though.
Also make sure your feed and return are not hooked up backwards at the rail
Old Jun 4, 2012 | 09:14 AM
return is going into the fpr side of the rail. thats rite? and i cant hear the pump prime. like lits not getting power but i metered the 3 wire plug going into the top of the cap and i have power to one of the 3 when i turn the key so imma try n hardwire it to see if the pump is good when i get home and go from there
Old Jun 4, 2012 | 07:34 PM
RodFarva's Avatar
Pump could be DOA, if it were wired backwards it would run backwards, been there done that.
Old Jun 4, 2012 | 07:43 PM
David48's Avatar
I <3 usdm
Oooor, it could be the clutch safety switch. Snip off the plug behind the clutch pedal and touch the 2 wires together to make sure it's not a faulty switch.
Potato
shit got all davided up.
Old Jun 4, 2012 | 08:04 PM
the pump should prime weather the clutch is in or not once the key is to the on position it should kick on and the car cranks but wont start.
STLNC04
May 5, 2014 06:53 PM
elitist
Nissan/Infiniti Tech
Dec 30, 2007 10:04 PM
Hybrid_Ej1
Apr 16, 2006 07:29 AM
bfro5
Jun 19, 2005 12:03 PM
paulwelican
Jun 21, 2004 10:06 AM
