problem with fuel cut off?
ok guys when i step on the gas the car hesitates (like if i let off the gas real quick then hit the gas again) and it acts regular after it hesitates? do you think its the ecu cuz i bought it off a guy off of tr and i might of been messed around with? any ideas lmk thanx TR
EJ Crew Member #2
Modified ECU? Sounds like it doesnt have enough fuel at those load points.
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
* IP E-Mail
* IP Face Book
* IP Web-Site
It might be the ECM or the connections between the throttle kicker's switch and messaging to the ECM, check to see if the kicker isn't the problem, but i doubt it, but if it is, the ecu isn't getting the message from the kicker that it needs replacing, because it's a minor defect of the kicker. To check the kicker you need to pop the hood and check your throttle lines and the kicker looks like a baby hand sized torque converter. when ever the gas pedal is stepped on the kicker is tugged when the throttle is stretching when opening. It might not be tugging the kicker right away and not giving you that automatic kick, but istead pulling the throttle fa have a sec and then pulling the kicker which gets you to thinking it is hesitating.
No project currently. Getting my ASE Certifications Completed.
WTF are you talking about?
Anyhoo, Sounds like a tip-in issue, does it happen at any RPM? If so it does sound like that ECU was mabye chipped?? or mabye the incorrect ECU for your application and is causing a over-rich condition or a over-lean condition, Which ECU is it?? Were you told it was chipped? throttle cable would have nothing to do with what is happening to you(unless its loooooooose as hell
) which I doubt.. let us know, Also I would check your plug wires and plugs, fouled plugs or bad wires/wire can cause a tip-in like feeling.
Alot of cars on the road will go lean for a milli second when you hit the gas hard, its not that uncommon, but yours seems to be doing it a little to long. LMK if I can help
^^^^^^WTF are you talking about?
Modified Racing
Street Tuning & Dyno Tuning the greater east coast area for over 10 years and running!
AEM/HONDATA/MOTEC/FAST/DEFI & More
EFI-101 Certified
(941)628-4988
EFI-101 Certified
(941)628-4988
i had the same problem in my car. i had 2 problems, my airfilter was dirty as hell and my injectors where kloged. go to discout and get a new filter and some injector cleaner and see if that helps first, that way if it doesnt help you only lost about 15 bucks.
Originally Posted by oemcivic0888
i was told the ecu is untouch and its a p75 thanx
Modified Racing
EFI-101 Certified
(941)628-4988
EFI-101 Certified
(941)628-4988
the ecu is a p75 and he has an obd1 ls motor. the ecu is throwing codes 21 and 23 which are knock sensor and vtec solenoid. we put in a stock p75 and the car ran worse. it was jerking everytime he got on it. i believe its a fuel issue. im not really sure.
Well if the car is throwning a VTEC code then its not a P75 which is a Non Vtec motor? Or someone was playing with the ecu and made some unwanted changes?? And Im confused, I was under the asumption that he was running a SOHC motor as in his sig??
Modified Racing
EFI-101 Certified
(941)628-4988
EFI-101 Certified
(941)628-4988
