sr20det transmission grinding problem need help!!!
Old Jul 1, 2011 | 11:06 AM
  #21 (permalink)
patriots14's Avatar
anyone else?? ask question i dont care lol i need to figure this shit out
Old Jul 1, 2011 | 11:52 AM
  #22 (permalink)
mewantkouki's Avatar
no
Replace everything and if it still makes noise buy a new car.
Everything you've posted points to the transmission as the culprit.
Old Jul 1, 2011 | 01:13 PM
  #23 (permalink)
patriots14's Avatar
yea but for to broken trans to have the same problem???
Old Jul 1, 2011 | 02:31 PM
  #24 (permalink)
patriots14's Avatar
and i have rplace everything besides the driveshaft and clutch but like i said clutch looks brand new.. its missing 2 bolts but i doubt that would do anything
Old Jul 2, 2011 | 03:26 PM
  #25 (permalink)
patriots14's Avatar
anyone else????
Old Jul 2, 2011 | 04:12 PM
  #26 (permalink)
Z28ricer's Avatar
Doesnt see what you did
Sell it, buy a fucking car with a warranty, something that you stay out from under.
Because you've already been told the problem, and keep asking for more solutions.
Replace the transmission, or better yet, have the damn thing properly rebuilt.
Or just stop asking.
Old Jul 2, 2011 | 05:33 PM
  #27 (permalink)
patriots14's Avatar
already tried the trans so that why im asking for other solutions....
Old Jul 2, 2011 | 06:30 PM
  #28 (permalink)
Z28ricer's Avatar
You replaced a busted, old used up transmission, with another busted used up, old transmission
You cant solve the problem when the junk you're putting in is the same as the junk youre taking out.
Get one properly rebuilt.
Old Jul 2, 2011 | 08:12 PM
  #29 (permalink)
patriots14's Avatar
do you know of a shop that can do it
Old Jul 3, 2011 | 07:33 AM
  #30 (permalink)
Empire's Avatar
buildin' it
Pretty much any transmission shop can rebuild a transmission... its what they do. call around to all of the ones locally and see what you can get for prices.
In the mean time, I would suggest getting your hands on a new clutch kit. preferably something stock, and has all of the bolts.
Then, to rule out the possibility of it being your driveshaft, find a shot to inspect it and balance it as needed.
I'd suggest getting a new pilot bushing too.
So far, you've thrown a lot of parts at it, but, in my opinion, all of the wrong ones.
I just re-read your first post. You took it apart and your flywheel had "dings" in it and that didn't throw up a red flag? And what was the justification for replacing the master and the slave cylinders? What the clutch fork not moving? Did the slave not extend fully? Where you loosing fluid?
You've done all of this work and you have yet to replace the clutch and pressure plate. The only parts that are directly related to the things you say are going bad (IE Throw out bearing)
If it was my money, I would have started with a brand new, complete, OEM replacement clutch kit. (I seriously doubt you need anything more than that anyway)
For you to have broken two transmissions so badly that the car won't move is pretty impressive given the amount of power I would assume you are putting down. Usually, the syncros will go bad and you'll have some grinding going in and out of gear, perhaps even a tough time getting it into gear, but once it is in, it will move the car. You're saying you have it in gear and the car won't move.
Unless your driveshaft is way way way dented and bent, The only thing I see causing that kind of a problem is a totally shot to shit pilot bushing, or a fucked up clutch/pressure plate.
So now, you need another new/good tranny. I would highly suggest that you replace all of those parts that might be causing the issue before you kill another tranny.
slicshoes
Feb 3, 2010 02:44 PM
98gsturbo
Jul 10, 2007 06:40 PM
Ender.
Nov 5, 2005 01:08 PM
cokeman19
8
May 2, 2005 11:39 AM
