sr20det transmission grinding problem need help!!!
Old Jun 30, 2011 | 07:43 PM
Z28ricer's Avatar
Doesnt see what you did
Originally Posted by patriots14
fuck v8s lol i will stick with my sr but i need help lol anyone else
Yeah, those things fucking suck, same fuel mileage, similar weight, easier to work on, and fucking transmissions that are a bitch to blow up.
Shitty, shit.
Old Jun 30, 2011 | 07:55 PM
mewantkouki's Avatar
no
I was just playing Devil's advocate. Truthfully, this SR will be my last 4 cylinder engine.
Old Jun 30, 2011 | 08:26 PM
Z28ricer's Avatar
You were only supposed to be amused.
Mainly that you're 2/3'rds the way down the road I went...
Old Jul 1, 2011 | 05:12 AM
patriots14's Avatar
yea i wish i could enjoy my sr lol i traded for the car got to drive it for like 4 days and its been sitting for like 2 months ... ive dropped the trans 4 times lol no one can tell me what the problem is ...
Old Jul 1, 2011 | 06:26 AM
elitist's Avatar
TR Balla Donor Supreme
could very well be the clutch. when you shift and it grinds will it actually go in gear or it won't go in gear at all? If it grinds when going in gear but actually does gear its probably the trans if it won't go in gear at all but the transmission bench shifts ok its probably the clutch. if neither of those are right remove the driveshaft, cap the output shaft hole, start the car and see if it shifts, if it does chances are its a driveshaft issue.
Old Jul 1, 2011 | 07:28 AM
patriots14's Avatar
well when im shifting it only makes a lil grind for 2nd gear sometimes.... the main grinding happens as im letting go of the clutch to move
Old Jul 1, 2011 | 07:47 AM
  #17 (permalink)
patriots14's Avatar
now if i rev it higher it will sometimes grind just a little bit or not at all and i can drive it but i have to rev it high to go and idk the rpm cause my tach dont work
Old Jul 1, 2011 | 09:50 AM
  #18 (permalink)
Z28ricer's Avatar
Its the transmission....
Old Jul 1, 2011 | 10:04 AM
  #19 (permalink)
Empire's Avatar
buildin' it
might be the operator
well, installer... not using enough, or the right gear lube.
i've seen kids eat through half a dozen transmissions putting a quart of 10w40 in them.
Old Jul 1, 2011 | 11:01 AM
  #20 (permalink)
patriots14's Avatar
2 quart of mobil 75w-90 is what i put it in.. the first trans had a lot of metal shavings it in but the one in it now has none the gear oil was clean..
