Brake Woes...
thats because your getting them up to operating temp. iirc they have a pretty high nominal operating temp
if you havent been in a small plane its worst, cause your eyes and brain say we are moving and your body says oh no we are not. eyes and brain go asshole we are moving, cant you see? body says fuck you we are not moving at all. so they fight and fight and eventualy your body says, you know what fuck you brain, see if you can stop this!! then you throw up.
seriously, it's so annoying and embarrassing that i might just swap out to OEM pads, and cut my minimal losses on stopping power, cause the shit's loud as hell, and i can't stand it... has me just slamming the brakes in anger some times... i'm kind of a perfectionist, and don't like when things make noise, funny idles, slight misfires or any of the sort, so for my brakes to be making that much noise? it kills me...
not really help but
Answer for Hawk HPS brake pads squeal!! - MY350Z.COM Forums
alot of these guys seem to have some squeel.
you grease em yet?
edit: this was probably the first thing you read, lmao
you grease em yet?
contact admin@tamparacing.com to advertise on here.. - mod
EDIT: oh, found the only part number myself... 40206-05U02
http://www.mynismo.com/products/?id=2897
all GTR options are drilled... 296mm. x 32mm... guess OEM Nissan engineers are derp derp derp derp....
guess the only retarded option is CROSS DRILLED rotors, unless i want to convert to R32 GTST brakes, in which case, OEM's are plain...
even the OEM GTR rears are drilled, but they are also the same as Z32 so i can use the non retarded part from another car if need be....
