I lose brake pressure every so often.
so now that everyone has addressed the OP's problem, i want to address the fact that the title is all kinds of fucking stupid. stop working on cars and go read a dictionary...
Nissan North America - Canton
oh by the way.. STOP BEING A TROLL!
I fixed the title for the SS grammar trolls.
actually, more often than not, you don't hear anything. really, the only times it will make a noise is if you warped the rotor and that is causing a, going to quote my girlfriend on this one, a "frub frub frub frub frub" type noise... or if the pads are going bad/are bad.
Only had one caliper seize on me and it was 100% unexpected.
1985 Dodge Conquest-SOLD
1990 Mazda Rx7 GTUs-SOLD
1990 Nissan 300ZX TT-Traded
1993 Nissan 240sx-Traded
1994 Ford Thunderbird SC-Totaled 6/11/10
1990 Nissan 240sx-SOLD
1995 Nissan 240sx se-SOLD
1994 Nissan Altima gxe-DD
what did yours sound like?
typically they don't make noise. All it is doing is applying brake pressure and if you have decent pads, they aren't going to make noise.
Sometimes, if you're driving and it takes its time to seize, it can get stupid hot and glaze over the pad and that will cause a bit of a whine/screech/scream
i dont know if it's been said yet or not, but i would take a step beyond bleeding them and actually flush the fluid out. brake fluid only lasts for so long and moisture eventually kills it. crack open all four bleeders and let them gravity bleed (means, dont pump the pedal, just let gravity do the work) and keep filling the master with new fluid until clean fluid leaves the bleeders. you'll be surprised at how dirty the old fluid is.
RIP Tim. i miss you, buddy
I thought it lasted forever
j/k. Now on to the problem. sounds to me like you have some sort of a vacuum leak at the booster causing the pedal to lose the booster assist. Maybe a bad hose thats collapsed on the inside and when ever the engine pulls a lot of vacuum ie (letting off the gas to slow down) or a bad valve as mentioned before.
Honda/Acura certified Technician
Lexus/Toyota certified Technician
ASE certified
1992 Eagle Talon TSi AWD sold
2003 Maxima SE
ASE certified
2003 Maxima SE
i took off all my wheels to inspect the rotors before bleeding them. i noticed a slight line that looks like the beginning of a crack in the drivers side front rotor. it also hasn't been doing it lately apart from last night when it did it for 3 stops then didn't continue. but when it does it and i park the car i can clearly smell brake fluid and when i was changing my axles the other day whattodobo noticed that it smelled like a locked caliper back there. i couldn't smell anything but i trusted his judgment.
i also haven't gotten around to bleeding them yet. i have some bad toe in my rear drivers side wheel and it ate my tire to death so i haven't been driving it. i have also been working on Tyler's car non stop and quite honestly forgot to do it, but ill give Stage_3 a call today and hopefully he can come over here and we'll get s*it done and will have an update for you all.
Thanks for all the awesome input. i really don't want to rear end someone because my brakes decide all on their own that they don't want to work. lol.
