I need cams installed and timing done
Just rent a leakdown tester... and bdc each cyl you are testing. You will know u have bent valves if you see more than about 20% you got the bends in your motor.
martin
martin
You bring tools in, remove the parts you want, pay lots less than other junkyards, and are able to get only certain parts that arent available at a lot of others.
I'd suggest a cordless drill that will fit a 1/4" extension, and a cordless impact, they should speed along removal.
