I need cams installed and timing done
Unless you broke the cam by installing it wrong ( cam caps tightened down in the wrong order against stiff aftermarket springs ) and you broke it while the motor was spinning, the chance that you did not cause valve damage is about 25%... Why ? because a stock SR cam has about 248 degrees of duration which is about this number. Then you add in the fact that the cam still is spinning forward when it breaks. Pulled a lot of heads and usually broken cam = bent valves.
This, probability isnt on your side, numbers dont lie.
Though now that I stop to think about it, the stock duration is at .006 or so valve lift, numbers at .050 are probably more like 208* or so, and im sure even smaller at enough lift to cause ptv contact, not as likely as it seems on the surface, but it would just suck to do all that work only to have to take it right back apart...
