LSD Driving Impression...
Old May 13, 2010 | 10:46 AM
  #61 (permalink)
LongFellow's Avatar
Please hold...
I'd probably just leave the stock manifold on it, port it and run a really short intake and a 60-65mm throttle body. Trying to make the GTi-R manifold work would cost to much money and be a total pain in the ass, though it'd be cool.
Team White Car 2010
Old May 13, 2010 | 10:55 AM
  #62 (permalink)
rhart's Avatar
Because race car…
Thanks for the clarification. The info I pulled was from Wiki...so take it for what you will. We all make due with what ever lump we have under the hood and most wish they had something different or some modification done to it that money or time somehow limits.
The idea of having a SR powered car that was along the same lines as the S2000 would be cool. I'd like to think someday I could drop in an aluminum blocked power plant into my ride but for now I have to settle.
Back to LSDs, Drive-Line, and suspension though...
Have you guys done the subframe colars and poly bushing. I figure since i was there swapping out the diff might as well do it right.
VLSD, Bushings, and just picked up aluminum uprights from a Z32 should be a decent upgrade package...brakes and 5 lug to follow soon there after
If it has tires or boobs it's going to cost you money...
Old May 13, 2010 | 11:00 AM
  #63 (permalink)
LongFellow's Avatar
Please hold...
I have ES ploy bushings milled down so the subframe sits flush against the chassis, and ES poly diff bushings (S14 only.) I'm happy with the results.
Z32 uprights are a sweet upgrade for S13's. I just ditched mine on my S14 yesterday because they dont really work that great due to the shocks being much longer. But they're a lot lighter. I would advise against poly bushings on/in anything that has to rotate to any degree. They make good mounts and rigid bushings, but if it has any sort of movement then dont use them. They run out of grease quickly then bind horribly and actually become worse than the stock bushings.
Q45's are a cheap solution to larger brakes, virtually same rotor size as Z32 and pad surface area. Only down side is they dont look as cool.
Team White Car 2010
Old May 13, 2010 | 11:08 AM
  #64 (permalink)
rhart's Avatar
Because race car…
I got the z32 rear brakes with the uprights. I do believe that there is someone with a front Q brake set-up for sale right now on here.
Good advise for a daily type car...polys would be best served for Sway Bars and the subframe mounting points and not so much for the control arms and such then.
Old May 14, 2010 | 06:48 PM
  #65 (permalink)
Tallgeese0721's Avatar
ii hito Kei
Originally Posted by LongFellow
You can drive mine on the auto-x course if you want. I think you'll be surprised at how different our cars are.
I drove the two last event and WOW was there a difference in tuning styles. It was then that I did everything I could to mimick the feeling I had in Dan's car We do have the same goals.
Driving with the helical gave me more confidence to push the car in grip, whereas driving the drift car with the 2way was a very... how should I say... limiting experience? I guess if the load was set lower and the alignment better, perhaps it would have felt different. But the car either wanted to oversteer or straighten up... I was pretty impressed with my times at that event with how much I held back (or felt held back) in that car.
For all around, I would say vlsd... If you want something "for little bit of this and/or that", it's a lsd that would do ok in slide or grip applications and still be civil. Hope my opinion and miniscule experience helps
Old May 18, 2010 | 08:25 PM
  #66 (permalink)
Speed cat's Avatar
speed cat
driving on acid iis a bad idea.....altho it can be done
Old May 19, 2010 | 09:11 AM
  #67 (permalink)
4wheeldriftS13's Avatar
February - Ride of the Month
Is it sad that this is one of the only tech related threads in Nissan tech right now?
RIP Tim Aldrich
Old May 19, 2010 | 11:15 AM
  #68 (permalink)
rhart's Avatar
Because race car…
Yeah...it is rather sad. Well, there is the one on the squealing belts.
Old May 19, 2010 | 11:29 AM
  #69 (permalink)
rhart's Avatar
Because race car…
I think it mentioned it already, but I did end up getting those z32 uprights. Now on looking for either ZX dampers or rear coil overs (folk type mounts anyway). Also still looking for the 4.36 diff, but time and money are a little short right now. My 240 and $$ is in the shop getting squirted, back to its original Sapphire Blue after rocking tradition TR matte black. i'll have before and after pix in a few days.
Old May 19, 2010 | 11:55 AM
  #70 (permalink)
Z28ricer's Avatar
Doesnt see what you did
koni sports are $112 ea from tirerack right now, get those, some sleeves, and a pair of springs, you'll have new useful coils for the rear, for less than some busted ass junk used coils you'll find around here.
