Clutch issue
Old Jan 15, 2009 | 11:32 AM
longfellow2's Avatar
FORE:sight
Get a PPG gear set and you wont have this problem anymore.
Originally Posted by Epstein
Old Jan 15, 2009 | 02:42 PM
240_kid's Avatar
I thought that was the issue, ok I'm glad to know; I thought I might have been doing something wrong.
Old Jan 18, 2009 | 07:46 PM
Jeff_TT's Avatar
Trying to keep a Z runnin
Z32's have the same issue. If you do not get the RPM match just right then it does not like to go into first gear while rolling. I just blip the throttle (like heal and toe downshifting) to get the RPM's up and usually the gear shift will slide right in as the RPM's drop with just slight pressure. If it takes more than that I woulwd suggest bleeding your clutch and verifying the fluid level as well as checking the free play on your clutch pedal. As the parts wear on cars of this age it may need adjustment to properly disengage the clutch.
"You will spend 10% of your money getting the first 90% of your Horsepower, but you will spend 90% of your money getting the last 10% of your Horsepower" Quote from an old racer guy I know!
Old Jan 18, 2009 | 08:03 PM
A-ron's Avatar
(SHIFT-YOUR SHITS WEAK)
i never have problems going into first.
the way i think of it if ur still rolling 2nd will do just fine.
somtimes when im moving if i try to go into first and it dont want to i slow down more.
it's like the same setup as if you were in 5th gear it wont let you go to reverse with out going into neutral first. but it wont let you go into first when going a sertin speed...
Drifting:
most fun you can have
with your pants on.
240_kid's Avatar
Yeah I think that is the issue, thanks Jeff.
