300zx Problems(I Need Help)
Old Jan 6, 2009 | 01:45 PM
sirmichaelthe3's Avatar
ok wel to answer the first question about the spitting i think before so it may be the turbo but i'm not smoking at all just when it is sitiing still and i get it to ilde right it spits from the drive side plus to think of it for a lil until it warms up it flexs in rpms just under 2300 so i know for sure it needs to be tuned cause my brother built it to handle 15 psi but right now i'm only boosting 7-8 ish so
but thank u for the help so for its just hard to work on someone else car and not know what he didi to it lol
Old Jan 6, 2009 | 01:49 PM
yeah i just read what k said and my brother switch from ball bearings to non so i guess thats another factor lol well i'm going to try royal purple cause i heard its great on motors and see where i go.......... and yeah i change the plugs but the guy give me na ngk's not turbo one if that would make a differents
Old Jan 6, 2009 | 07:40 PM
Mr. K's Avatar
I will say that my car used to spit oil (very small amt.) when I first started it. It wouldnt spit at idle, JUST when I started it up, but my turbos are still in awesome condition. The motor could have problems with the valves or something internally wrong. I dont personally know because I no longer have the problem with a new motor.
Old Jan 8, 2009 | 01:17 PM
thanks for the help! well i'm going to change the oil and spark plugs again and then and see where i get and i'll let u guys know.
Old Jan 8, 2009 | 01:24 PM
Mr. K's Avatar
check also to see if there is oil on ur plugs
Old Jan 18, 2009 | 08:23 PM
  #17 (permalink)
Jeff_TT's Avatar
Trying to keep a Z runnin
ok...after reading this twice I see no mention of color of the mist coming out of the exhaust. Also does it just happen at startup, cold, warm, etc.? My Z spits black carbon out when I start it but it stops almost immediately. It's because my car is running extremely rich at startup. You say he tuned it for 15psi but you're only running 8psi. It may be running extremely rich. I would second checking your plugs, I would verify the timing is set to 15degrees. I accidently clipped my timing light on the loop backwards one time and over retarded my timing causing a similar response.
As for the ticking...all z's tick at startup. but it should go away within a minute or 2. If not check the fuild level and consider changing the oil. Also make sure you are using the correct viscosity for the air temperature.
"You will spend 10% of your money getting the first 90% of your Horsepower, but you will spend 90% of your money getting the last 10% of your Horsepower" Quote from an old racer guy I know!
