Do transmission need a break in period?
Old Oct 8, 2008 | 09:48 PM
shinmei2006's Avatar
Default Do transmission need a break in period?
in general?
and
specifically the new computer controlled dual clutch in the GTR.
just want to get opinions on this. especially epstein and presidential_302
being that an engine (regardless of clearance differences between modern engines and past) reccomend/require a break in period, in essence the transmission too is being broken in.
if you have already broken in the engine (lets say the car has 50,000 miles) and replace the tranny, are you able to go all Tanner Foust or Dale Jr on it right after installation?
lets say the car has about 15 miles on it and you do a few 4500rpm/500ftlb tq clutch drops to try out the car. Any lasting damage?
http://www.hashiriya.net
Old Oct 8, 2008 | 10:08 PM
art's Avatar
art
E=MC-hammer
well comming from a shop where we had a tranny builder and craig can get down on this as well, it's not "a must" but is highly recomended if all part's are new or the majority of the gear's(manual)are new, it's new part's, and should be worn in and not beatup
IM IN VA BITCH!!!!!!
www.rccustomz.com
Old Oct 8, 2008 | 10:09 PM
miataspeed's Avatar
there is a break in period for trannies just like engines. this is all dependent on what was replace when overhauled or if i its all new. trannies have bearings and gears that may have too tight o tolerences and need to "seat" with each other. put in new fluid of the proper weight and viscocity run it or a couple hundred miles and then drain it and check or excessive metal particles i everything looks good replace fluid and go on your way. just make sure to service at regular intervals. but you are going to have people tell you theres no breakin period but their also the ones that say theirs no break in on engines. i guess everyone has there own preferences.
if you havent been in a small plane its worst, cause your eyes and brain say we are moving and your body says oh no we are not. eyes and brain go asshole we are moving, cant you see? body says fuck you we are not moving at all. so they fight and fight and eventualy your body says, you know what fuck you brain, see if you can stop this!! then you throw up.
Old Oct 8, 2008 | 10:13 PM
art's Avatar
art
E=MC-hammer
most of the V8 guy's i knowbut old V8's are mile's of gap when compaired to most import's
www.rccustomz.com
Old Oct 8, 2008 | 10:14 PM
updated original post. thanks guys.
Old Oct 8, 2008 | 10:25 PM
art's Avatar
art
E=MC-hammer
what did you do?
www.rccustomz.com
Old Oct 8, 2008 | 11:07 PM
miataspeed's Avatar
yeah i dont care how strong a tranny is you put that kind of abuse through it, its going to break. i would even worry about breaking it in, it's not going to last doing that whether its broken in or not
Old Oct 9, 2008 | 03:27 AM
Epstein's Avatar
Retired
Lets look at a few things here. You "need" to break in an engine to refine/hone the piston rings to conform with the cylinder walls. That's about it. The bearings/crank/rods don't actually touch each other and are separated by a few thousandths of oil film. On a performance rebuild with hard rings, the idea is to run it in hard because the walls will have a slight texture from the final hone which will sort of file against the hard rings. Works great. 20 min idle then straight to the dyno at low boost. Then there are cars like the Z06 where break in is done for you at the factory, so you can lay rubber at redline right through GM's parking lot on the way out.
Transmissions are different. They use roller/ball bearings, which shouldn't need any break in. The gear meshing should be checked at the factory so I don't think it would need any real break in save for delivery miles. I'd be more concerned about the clutch/pp/flywheel break in, like you should be familiar with on any new clutch. That's more for holding power though.
I mean, consider this: most people debating in this thread have pulled a magnetic trans plug on a stock FS5W71C. There's not a whole lot of fuzz on it after 100k+ The whole idea of a break in process is to refine the mating surfaces. That means removing material. At no point in this process does anything magically become stonger. We're talking about longevity with regards to wearing out, not catastrophic failure.
I know what this is about. It's about that GT-R transmission. It just has weak clutch packs. No one is talking about gears exiting the case or being stuck in "neutral", etc. We're talking about losing the 1-3-5 or 2-4-6 gears. These sets have their own clutches. When that clutch fails, you lose that set of gears. As far as a clutch drop, you can't really do that in a GT-R. It slips the clutch for you. The problem with dropping is shock loads. The GT-R trans is on a carbon driveshaft that will have some deflection, and is on a rubber isolated subframe. Compare this to a traditional setup where the trans is bolted directly to the engine and crank where no deflection can occur. And the problem with shock loads is breaking gears. I don't think anyone is breaking gears here.
Nissan's 20k trans.... That's because they're Nissan and won't open it up to fix the broken bits. The entire transaxle is 20k. They did the same thing with VQ35's that drank oil and FS6 trannys that grinded. In both cases (rings, synchros) the fixes were less than $100, but they would swap whole assemblies. Do you think any dealer wrench (with or without 12 hours of GT-R slideshows, er training) could sort through a tranny like this? Best case would be FedExing it back to the BW factory. I think part of this is making an example of idiots who break things after a week, and setting precedent. This is just Nissan saying that they won't fix every idiots tranny for free because they like to show off. People seeing failures in normal or spirited use should be getting freebies.
Old Oct 9, 2008 | 06:35 AM
lordofthemiasma's Avatar
RIP DJ YOU WILL BE MISSED
there are so many douche bags on here mainly in gen. car chat that hate on this car so bad. bunch of douches.
RIP my very best friend. DJ aka djzstang1 you will be missed dearly. I love you bro.
1995 240sx se
1992 240sx
1990 240sx se
1991 240sx hicas sr20det MDX
1991 240sx project coupe
1990 240sx drift beater hatch
1993 240sx sr20det
Old Oct 9, 2008 | 07:11 AM
Epstein's Avatar
Retired
I stand corrected. There are gear failures in these boxes. I doubt shock loads play a part. It still doesn't change the fact that, regardless of a "break in" period, the strength of that gear is not going to change over time. This is not a fine wine. We're not baking a cake here.
