VCR - How does it work?
Old Jul 10, 2008 | 10:11 AM
Mars_302's Avatar
Race Photographer
Default VCR - How does it work?
And im not referring to the home video electronic. I referring to Nissans new engine technology, I just wanna see a good explaination
This new 4-banger will feature Nissan's new VCR Piston Crank System. "VCR" stands for Variable Compression Ratio, and it does just that by using a multilink connecting rod/crankshaft arrangement.
In light load conditions, it will use high compression ratio and limited turbo boost to increase thermal efficiency and improve fuel economy. When stronger acceleration is required, the system will shift to a lower compression ratio and increase turbo pressure. The lower compression ratio allows higher boost to be used for greater power creation while avoiding knock or detonation.
Old Jul 10, 2008 | 10:17 AM
kairojya's Avatar
Rojya Productions
that's pretty cool, im interested now as well
Follow me: YouTube | Vimeo | 500px | Flickr | Google+ | Facebook
Old Jul 10, 2008 | 10:24 AM
BosnianLanos's Avatar
Daewoo Frankenstein
NISSAN | Variable Compression Ratio Piston-Crank System
...not gonna lie, kind of scared that overcomplicating something like that by adding so many more moving parts will yield lessened engine reliability.
Old Jul 10, 2008 | 10:43 AM
vertigo's Avatar
U and your 3rd dimension
Saab or volvo accomplished this many years ago by using a tilting head.
Old Jul 10, 2008 | 10:52 AM
vertigo's Avatar
After reading that link Bosnian posted, the system seems pretty interesting. That engine is going to be a tuning nightmare. Full sweep time from max c/r to lowest will be critical. I would imagine Nissan taking full advantage of the fly by wire system to 'deaden' the users throttle input. ECU aftermarket for this engine will be nill. Looks like our hobby will be fairly dead soon.
Old Jul 10, 2008 | 11:44 AM
quiksilvia's Avatar
im afraid to say this but is this gonna be the new silvia motor????
that's the only motor that come's to mind with the turbo and all
VV Pasco Meet every friday! VV
Awesome Pasco Car meet evey Friday!
Originally Posted by EclipseGT01
Try and get people at ANY car show to come around a Grand Prix or a Regal.... they simply wont because there is a lack of interest in those cars. Not saying they can't be fast... just saying that my WRX will always attract more pussy than your pontiac
[Insert Awesome witty car list here]
[§]Hellabroke Ballin aint free! [§]
Old Jul 10, 2008 | 11:56 AM
Epstein's Avatar
Retired
Uh, wouldn't it be easier to adjust the CR dynamically with cam timing? You know, run it in Miller Cycle under boost and revert back to high-comp Otto cycle while off boost?
I like Vertigo's thinking about tuning.... With all that complexity flinging around, just think of the giant mess you'll make on the dyno if you get it wrong!
Old Jul 10, 2008 | 12:16 PM
Z28ricer's Avatar
Doesnt see what you did
Whoa noez ! Quick someone let nissan know they screwed up, high compression is for boost and power, low compression is for fuel mileage.
R.I.P. Tim
RB $200
LS1 $250
Old Jul 10, 2008 | 12:32 PM
vertigo's Avatar
static c/r is more than just the compression stroke. The EXPANSION ratio is what contributes a significant amount to the increase in power / efficiency of a high compression engine (although you could probably get away with a slightly higher c/r in a miller engine). The miller cycle does nothing to increase the expansion ratio, and adds cost + complexity. The basic idea behind the miller cycle is, the first X amount of degrees from BDC is the least efficient at compression due to lack of mechanical leverage, so delay the compression stroke X amount of degrees and let some of the intake charge revert back out of the intake valve. In the Mellenia's case, it has the internal friction of a 3L, with the tq of a 2.3. Also remember that engine runs a lysolm twin screw supercharger which is very expensive.
If the c/r sweep is large enough for this motor, and it can stay in the optimal c/r at each load point, it will produce significantly higher efficiency #'s than a miller.
Old Jul 10, 2008 | 12:33 PM
vertigo's Avatar
Not sure if you are joking.. but high c/r is for fuel efficiency, low c/r is for power on pump gas.
