Who has built their own engines?
I have built my share. The only "advice" I have to give is... Measure everything twice. it is like the old saying measure twice cut once. Get as much information about your build as you can, ask other people who have built that motor before. Go into the fsm do not be intimidated to admit that you dont know and ask. the only stupid question is the one not asked. If you are not sure of a measurement do not move on look it up in the fsm get it right feel confident about it then move on. The worst feeling you can have is building a motor and thinking to yourself I hope that was right. There is always a right tool you cannot build a motor "well/correctly" without them. Perfect example try building a motor without a micrometer, a dial indicator, plastigauge if you must. People used to laugh because I would and still do bag and lagel every part I also have different boxes if I build the whole car; motor, engine bay, interior, rear suspension etc. choose to have a high attention to detail. I have seen many builders over the years and one thing that all of the good ones had was a high attention to detail. When you stop, stop after you tightened what ever you are working on if you have several projects that are similar, consider leaving yourself a note as to where you left off. It would suck to assume that those head studs were in more than handtight. Cleanliness, the section of tomei where they build motors is in a vacume environment conver the motor at night, use brake clean, keep your parts and materials free from foreign matter. In the end remember that time and money are both forms of currency and you only get what you pay for, or your build will only be as good as the time and money you put into it
http://www.hashiriya.net
hahahahhaa.
hey martin my engine has officially outlasted yours
it's in ross petty's car now.
i'm trying to buy it back.
rest in peace tim.
rest in peace tim.
Anybody know where I can get a hard-copy of a FSM for a 89-90 S13?
I have downloaded a few of them, but I really want a hard-copy.
-'03 GSX-R 750
-'03 GSX-R 750
clevitte assm. lube
king bearing's
know what you are building it for i.e. stock,street,N2o,forced induction ext... spec's change so much basing on what you are building it for as well as part's
clean it twice!!!
assm. in a clean room or area!
double check the part's you get from the machine shop dont just take there word for it people make mistake's dont make it your mistake...
check all you part's gaskets and seal's!
have the right tool for he job and double check your trq. on bolt's
if you not sure about the specs check around dont just take some one's word on it
ask if you dont know/ to many people dont ask and regret it in the end...
mark your rod's
plasti-gadge your bearing's!!!
check you ring gap's
dont assume there right
if a part look's bad DONT USE IT!!!!
but there are just a few and a life long rule for your automotive project's is
cheep, reliable, or fast.....choose 2....
there is so much more but there are a few
art
king bearing's
clean it twice!!!
mark your rod's
art
IM IN VA BITCH!!!!!!
www.rccustomz.com
www.rccustomz.com
like they said above.. CLEAN CLEAN CLEAN!! invest in latex gloves your nasty fingerprints arent even cool on an engine.. probly wont hurt it but just be anal.. clean everything.. check every measurment.. torque every bolt.. im not talking just studs and rod bolts and stuff.. when you do it right ... DO IT RIGHT!! torque the oil pain v/c and everything man. do it all to specs.. and like they said before me find an engine builder to help you with specs like boosted motors can have a little more clearance on the piston rings than n/a motors.. make sure every gasket surface is spotless.. no fingerprints nothin.. measure everything.. then measure it two more times.. plastigauge is your friend dont be afraid to be liberal with it and check every rod not just one and assume others are right. actually dont assume anything.. if you dont KNOW it will run when your done.. you need to tear it down and check everything again lol.. ask lots of questions and study that FSM like your life depends on it.. and again.. KEEP IT CLEAN!! during my engine build i used black trash bags to cover my engine.. and every night i went in after working on it.. it got a diff bag.. the old one was thrown aside.. then first thing i did the next time i worked on the motor was check my previous work.. then started new work.. dont be afraid to check everything.. dont put the oil pan and v/c on untill your ready for the motor to go in the car.. and be EXTREMELY liberal with the engine assembly lube.. you spent a lot on your parts.. make sure they stay ncie lol..
