I'm officially out of Ideas on what else to check on my 93 KA-T.
Old Feb 18, 2007 | 03:56 PM
+Waldo+'s Avatar
Electronicals master ;P
my sr has the same problem bro... damn thing is spooling fine and just sits fully boosted, but my RPM's move real slow, and the car seems to like lag... it only does it everyonce in a while... ill let you know if i find out whats up. hope you figure it out gl
Sponsored By Carrabba's
R.I.P. Tim Aldrich
Old Feb 18, 2007 | 04:05 PM
BOX SENTRA's Avatar
OG MUDBONE 240sx
maybe the car is reading knock from lifter tick. i dont know how sensitive your knock sensors are, but on my car it would read knock (like 12 degrees being pulled) and go really slow, i found it was lifter tick causing it, changed the oil and it went away, no timing getting pulled. it came and went just like your problem.
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old Feb 18, 2007 | 04:32 PM
JDMbyBlood's Avatar
I also thought it may be the knock sensor. I replaced it with a used one and moved it off the block just to see if it helped and it didnt. I priced a new knock sensor and was quoted $179.00 )
Old Feb 18, 2007 | 05:02 PM
BOX SENTRA's Avatar
OG MUDBONE 240sx
do you notice any bad lifter tick?
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old Feb 18, 2007 | 05:29 PM
JDMbyBlood's Avatar
There is some lifter tick, but really nothing that bad. Car has less then 1000 miles on oil change. The one thing I did not do when hooking up my SAFC II was set the knock sensor feature. I did it last night, maybe that had something to do with it running well all day today. I guess I'll see if that helped.
Old Feb 18, 2007 | 05:35 PM
Sohc4now's Avatar
^^^I'm with stupid
it could be your brakes/caliper. get a infared temp gauge and see how hot your rotors are when its acting up.
Old Feb 18, 2007 | 05:53 PM
  #17 (permalink)
BOX SENTRA's Avatar
OG MUDBONE 240sx
are you running methanol? my oil breaks down real fast and i get 1000 miles out of an oil change from the methanol
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old Feb 18, 2007 | 07:03 PM
  #18 (permalink)
Failure's Avatar
Fail
put it on a logger and take it for some runs when its acting up and see whats goin on.. that will tell you whats goin on. knock pulling timing w/e i dont know if there are many loggers for s13 ive never had one. gl finding it..
Speed Kills, Drive a honda and live forever
Originally Posted by Kirk
Failure for President.
Originally Posted by SuburbanNoize
Weve already got that
Old Feb 18, 2007 | 07:09 PM
  #19 (permalink)
dan's Avatar
dan
Get the fuck off my lawn
any nissan dealer has a consult. or try finding a very rare techtom mdm (will be expensive).
hooking up knock sensor on s-afc wont change it, just shows you the readout. if u calibrate it good you can see if your knock sensor is functioning or pulling timing during driving. mine would only make knock at idle, just from picking up alot of vibration from the not so graceful KA, only other time i got knock was when i accidentally filled up with 87 octane and forgot, and i got on it one day and got a bit of detonation.
i think u have to have the car warmed up and let the car idle, then set the knock...it will always be reading something like 140 or whatever but when u set it, it sets 140 = 0 so that anything more will be considered above normal or whatever. good luck on that.
i might be heading to st pete tomorrow to sell parts, maybe i can come look at it or something. if not, id say you'll have to fork over some cash for a dyno run to check things out. while you're at it just throw down for a rom tune at xat or something, martin should be able to figure it out maybe. maybe your s-afc is just not perfectly set, so its doing odd things during certain conditions.
Old Feb 19, 2007 | 05:02 PM
  #20 (permalink)
KnightDrifter's Avatar
if your looking for a data logger or consult check this guy out, pretty good prices and fits alot of car...I should be getting mine 2morrow or so.
FS: High-quality CONSULT-I interface boards: Nissan Parts For Sale: Nissan Infiniti Forums - NICOclub
