I'm officially out of Ideas on what else to check on my 93 KA-T.
Old Feb 18, 2007 | 04:52 AM
JDMbyBlood's Avatar
Default I'm officially out of Ideas on what else to check on my 93 KA-T.
I'm officially out of Ideas on what else to check on my 93 KA-T. I've tried all suggestions recommended and can't find the problem. I had another post on this, but thought I would start a new one. This has been a major pain in the rear end. The problem comes and goes. One second the car would run like a bat out of hell, next min. it falls flat on its A$$. Still produces boost, but does not pull at all. (Won't even break traction.) You can floor the car and the RPM's would rise slowly, It's like timing is being pulled back way tooooo much. When the car is running fine the tires just spin through 1st, 2nd and when it grips it moves out. (Clutch will even slip at times.) I don't know what else to check. Here is a list of was done to the car in the last few weeks. I either replaced the part or swaped it out with another part to check it. The car was also put on a Snap-On computer looking unit to check for problems and all checked out fine. (Also no codes.) I am out of Ideas. Anybody else have anymore suggestions?
Thanks....
Replaced:
*Fuel Filter
*Fuel Pump
*NGK Spark Plugs (1 Step colder, gaped to .028 )
*Plug Wires
*Ignition Coil
*Knock Sensor (Also tried moving knock sensor.)
*New Air Filter (HKS)
*Water Temp. Sensor (Also replaced plug with new plug due to corrosion.)
*Waste Gate
*Cap and Rotor
Swapped out:
*ECU
*MAFS
Mods:
*Ignition mod
*Engine grounding mod
Checked:
*Hose Clamps
*Timing
Old Feb 18, 2007 | 04:58 AM
xnissan240x's Avatar
Fishes more than you
maybe a boost leak, check all your piping
Old Feb 18, 2007 | 05:51 AM
SLOW240's Avatar
welder/fabricator
my car kinda does the same thing it seems, that on my car and yours something is effecting the timeing but idk what it is, how well id your motor grounded to your car? it probably wont make a diffrence but u never know, my ka-t did the same thing and it was a bown head gasket id do a compresssion test
WELDER AND METAL FABRICATOR
http://www.myspace.com/welderfabricator
Old Feb 18, 2007 | 05:53 AM
SLOW240's Avatar
welder/fabricator
oh... mabye the little modual thing under the coil pack?....just throwing out ideas
Old Feb 18, 2007 | 07:04 AM
KnightDrifter's Avatar
Think back of all the times it has happen and what were the conditions like...for example was the outside temp cold or hot, full/low tank of gas, uphill/downhill, morning/afternoon/night, ect. Maybe your car is fine its just somthing else beside the components of your car cuase it drive bad.
I've heard stories of hard starts, low performance. They tried everything and couldn't figure it out, until the owner notice that it only happen with a full tank of gas. It ended up being everytime they filled up the gas tank it would expand and partialy squeeze the fuel line. well hope you find a common condition that will help you out.
Old Feb 18, 2007 | 07:07 AM
JDMbyBlood's Avatar
Checked and double checked all clamps and all is good. Did the ignition mod and did not help. Added extra grounding wires from the engine to the body and battery, no change.
Old Feb 18, 2007 | 07:21 AM
JDMbyBlood's Avatar
Car does it on a full tank, half tank and near empty. It doesn't matter how much fuel I have in the tank. I thought it may be the temp out side, but it does it when its cold and hot out. I thought it may be the Air Temp Sensor, but cant find one, unless its in the MAFS. I've tried swaping it out the MAFS and even bought that MAFS sensor cleaner and no change. Ive driven the car for 75 miles with no problems, then again it would at times change from light to light. A suggestion was made to replace the entire wire harness, but really dont want to do that. I dont think its the turbo set up or the engine. Car idles like a champ, not a single miss. When she is running good, she is running goooooood. Its seems to be either a bad connection or a bad sensor somewhere, but dont know of any other sensor I can replace.
Old Feb 18, 2007 | 07:32 AM
Jonas's Avatar
vaccum leak.
Jonas
Old Feb 18, 2007 | 10:05 AM
dan's Avatar
dan
Get the fuck off my lawn
-boost leak test
-compression test
-try swapping engine harnesses. if its anything of those related that u swapped, means the wiring is reason they are freaking out (knock, mafs, tps, coolant temp)
make sure the tps is reading correctly and the screws holding the sensor are tight. could be reading wrong or moving, causing wrong amounts of fuel to be in at different tps levels.
Old Feb 18, 2007 | 02:54 PM
JDMbyBlood's Avatar
Car drove fine all day today.
