KA Overheating?!?!?!??!
Old Oct 19, 2006 | 01:44 AM
asia989's Avatar
Why So Serious?
ive been burping it unless im doin it wrong, if i installed the theremastat backwards the water neck wouldnt go back on..
No Front Bumper Mafia crew#1 since 04'
The original 350Z Blue 240sx
Old Oct 19, 2006 | 03:32 AM
JimmyHat's Avatar
Sphincter Say's What?
have you removed the bleder screw and full the coolant until it somes out of the bleder hole? Thats how its done. Jack the front of the car up while your filling the car. There is a weep hole on the thermostat that allows air to pass through. With the car jacket up will allow the air to come out easier.
Old Oct 19, 2006 | 04:27 AM
Griffin400's Avatar
Saddlebrook
Also check your belt to see if its tight!
Old Oct 19, 2006 | 05:42 AM
SpottedMango's Avatar
Driven Concepts, Tampa FL
Running clutch fan? The clutch may have gone bad. Perform a leak down test and see if it might be a headgasket. Other then that, bleed the system using the bleeder screw if you have not done so.
Driven Concepts, LLC
1101A East Hillsborough Ave.
Tampa, Florida 33604
813-236-4500
Monday - Friday 9am - 6pm
WE ARE DIRECT
Tein, GReddy, Buddy Club, Bride, Tanabe, K-Sport, Power Enterprise, etc......
https://www.tamparacing.com/forums/d...ml#post4905630
Old Oct 19, 2006 | 05:55 AM
4wheeldriftS13's Avatar
February - Ride of the Month
Put some mountain dew in it Joe, btw I got the p/s assemb from Casey ** the belt was 20.00... so Im gonna put it in today.
RIP Tim Aldrich
Old Oct 19, 2006 | 07:20 AM
Deuche's Avatar
I had the same exact issue when i swapped mine. I ran dish sop through it fora bit to clean the debry out of te jackets. Then I used a vacum pump to fill the system. Basicly it installs on your radiator and youhook it to a Compressor it creats a vacum and you drop the hose in coolant and it sucks the coolant into the block. Its the only way i could get allof the air out of my new block. and i yet to get any heat. But it stopped overheating on me.
Old Oct 19, 2006 | 01:49 PM
  #17 (permalink)
asia989's Avatar
Why So Serious?
i am running the clutch fan, i might drop it by so you can take a look at it
Old Oct 19, 2006 | 01:52 PM
  #18 (permalink)
asia989's Avatar
Why So Serious?
only thing i can think of is thats theres stuff still in there thats clogging, I ran the water hose threw the waterpump opening when i took the pump out and got some rubber peice out along with rusty water.
Old Oct 19, 2006 | 02:22 PM
  #19 (permalink)
JimmyHat's Avatar
I have a S13 radiator you can swap it out and see if thats it?
Old Oct 19, 2006 | 02:48 PM
  #20 (permalink)
asia989's Avatar
Why So Serious?
is it an auto radiator?
