KA Overheating?!?!?!??!
Old Oct 19, 2006 | 03:58 PM
  #21 (permalink)
asia989's Avatar
Why So Serious?
well after being an idiot and opening the cap when the motor was running got me splashed with warm/hot water.Shut the motor off refilled till the radiator stopped sucking the water down.Started the car back up turn the heater on and blistering hot air came out.I think im in need of some e-fans now
No Front Bumper Mafia crew#1 since 04'
The original 350Z Blue 240sx
Old Oct 19, 2006 | 05:29 PM
  #22 (permalink)
RubberBerner's Avatar
Sideways Maffia
well if it stays cool when you're driving, and it overheats when you stop...thats obviously an airflow problem. If you have access to a high speed/velocity industrial fan, try idling with it blowing through your radiator. If both hoses are hot and the radiator has no spots on it that are obviously cooler than the rest, and you're not losing coolant...i'd say its deffinitely airflow. Check oil for coolant and vice versa though man...headgaskets on the KA's love to blow.
NOBAMA!
Old Oct 19, 2006 | 06:10 PM
  #23 (permalink)
asia989's Avatar
Why So Serious?
im hoping thats no tthe case with this one tho......thx's for the heads up
Old Oct 19, 2006 | 06:18 PM
  #24 (permalink)
170k240's Avatar
Will Drift For Tires
how many miles does it have? head gaskets seem to go around 120xxx to 150xxx miles
Nissan North America - Canton
Old Oct 21, 2006 | 03:17 PM
  #25 (permalink)
asia989's Avatar
Why So Serious?
188,000, but the motor isnt miss firing at all, the only kod it throws is the knock sensor.A couple of my buddys think swapping the coolant temp sensor might help get a proper read
Old Oct 21, 2006 | 04:08 PM
  #26 (permalink)
jcrock's Avatar
SR wishin'
Blown head gasket? Seen that a few times
"G-force is the only representation of true speed" <=
Old Oct 21, 2006 | 10:57 PM
  #27 (permalink)
asia989's Avatar
Why So Serious?
if the gasket was blown it wouldnt be starting right up and running , ive blown head gaskets before
Old Oct 22, 2006 | 05:05 PM
  #28 (permalink)
170k240's Avatar
i had a blown head gasket for 1,ooo miles before realizing it.
Old Oct 22, 2006 | 05:46 PM
  #29 (permalink)
Sideways Maffia
It could. I've had head gaskets run awesome but overheat after 10 minutes of driving. they could idle all day but the load created too much heat and eventually ran the temp gauge straight to H.
NOBAMA!
Old Oct 22, 2006 | 07:41 PM
  #30 (permalink)
170k240's Avatar
^thats what happened to me when mine blew
