problem starting my sr
Old Apr 24, 2006 | 07:15 AM
iburnv8s's Avatar
Default problem starting my sr
alright, this is my problem. sometimes during daytime driving i'll park my car and when i try to restart it the engine wont turn over. i can hear a clicking noise when i turn the key, which sounds like the starter solenoid. she seems to restart when the engine cools down. could the problem be corrected with radiator upgrade which is already in the works, or is it a starter problem? i need to adress this problem asap.
Old Apr 24, 2006 | 07:43 AM
NEWBORN240sx's Avatar
Turbo Dave
it sounds like to me its your coil modulator. what i would do is drive it and check to see if the modulator is hot, if so it needs replacement... i maybe wrong
Old Apr 24, 2006 | 07:45 AM
Torrential's Avatar
Built to guilt
I would vote for starter outta 2 things u listed.
Old Apr 24, 2006 | 08:39 AM
iburnv8s's Avatar
well the coil modulator kinda makes sense seeing that i've fried a couple of coil packs in the past.
Old Apr 24, 2006 | 08:58 AM
tak's Avatar
tak
A to the K
You said the engine does not turn over. That means the starter is not working. Check your starting system.
Old Apr 24, 2006 | 09:24 AM
Turbo Dave
i does your starter sound like a rotory sometime? if so it's your stater solenoid. also if your starter makes a clicking noise... you have a voltage problem, but you also said when the car cools down it will start with could be you coil modulator.. and one more thing does your car stall sometimes out of no were... if so check the coil modulator
Old Apr 24, 2006 | 10:49 AM
180sx-I's Avatar
DriftToy
I would say replace the starter. I have the same exact issue. But it has nothing to do with heat. I replaced my radiator, added electric fans, lifted the hood, and added a ram air. Still the same issue.
Old Apr 24, 2006 | 12:32 PM
iburnv8s's Avatar
the car doesn't stall out for no reason but i do see the rpm's drop a few hundred from time to time. i figured that was normal for and old engine.
Old Apr 25, 2006 | 05:46 PM
iburnv8s's Avatar
so i should be replacing the starter?
Old Apr 25, 2006 | 07:49 PM
180sx-I's Avatar
DriftToy
Yes! And let me know where you found it and for how much.
