problem starting my sr
Old Apr 26, 2006 | 12:11 PM
iburnv8s's Avatar
thats funny. i was going to ask you where to get one. but, if i find one i'll post it so we all know. thanks for the help.
Old Apr 26, 2006 | 12:18 PM
JimmyHat's Avatar
Sphincter Say's What?
How is the ground going to your motor? I had this problem when my motor was grounded incorrectly. It would start when it was cold but click click click when it was hot and i had to push start it.
Old Apr 26, 2006 | 05:14 PM
180sx-I's Avatar
DriftToy
Hmmm... Good question. iburnV8s is your battery relocated. I relocated mine to the trunk. Negative is grounded to the body in the trunk area.
Old Apr 27, 2006 | 06:55 AM
NEWBORN240sx's Avatar
Turbo Dave
also his battery many not getting a good voltage charge
Old Apr 27, 2006 | 06:49 PM
iburnv8s's Avatar
yeah, my battery is in the rear so i'll take a look at the ground wire.
Old Apr 28, 2006 | 06:46 AM
iburnv8s's Avatar
i took a look at the ground wire in the rear and it looks like its connected right underneath the battery box. should i reconnect it to the frame or is the a better location to get a constant ground. and my battery is only a yr old. i'm not running any subs so the battery should be good.
Old Apr 28, 2006 | 06:49 AM
  #17 (permalink)
JimmyHat's Avatar
How many grounds do you have? Do you have a ground in the front where the battery was located before and also a ground in the rear where the battery is located now? If you have 2 check the ground in the front.
