Leaky injectors
Old May 2, 2005 | 03:12 AM
SpottedMango's Avatar
Driven Concepts, Tampa FL
Default Leaky injectors
What are some signs of a leaky injector? Currently running top feed 72lb injectors on a SR. The car seems to be running very rich periodically. There seems to be a tremor every once in a while. Just want to add that the car's romtuned and as of right now it's running smoothly on the dyno.
Are there more obvious signs of an injector leak?
What are some tests that I can do in order to detect an injector leak?
Thanks guys.
Old May 2, 2005 | 03:34 AM
Durdan's Avatar
No Ants Drift Member
spray the injectors down with WD40 while the motor idles. if the idle changes, thgere you go
RIP Tim. i miss you, buddy
Old May 2, 2005 | 03:56 AM
So, bascially, if it's an o-ring or something, the WD40 will detect it much like a vacuum leak?
Old May 2, 2005 | 05:41 AM
craig_302's Avatar
boostmonkey
The smell of gas underhood would also be a decent indication along with visual cracks along the tops of the hats.
T61turboII
Mazda Tech
15
Apr 29, 2005 06:13 PM
greddy2die
Mazda Tech
Feb 10, 2005 12:19 PM
Matt Vassallo
Nissan/Infiniti Tech
18
Mar 24, 2004 08:36 AM
blackwagon
Subaru Tech
10
Feb 23, 2004 09:59 AM
