clutch sliping
Old Mar 25, 2005 | 06:27 AM
CAPESR20's Avatar
Default clutch sliping
my clutch starts to slip after only 20 min. or so. as I drive the peddle gets stiffer and then starts to slip. and on a colder day it take longer to start sliping. I have changed my master,slave. I have a new clutch put dont want to put it in till I figure this out. the clutch in there is fine thow. any suggestion
Old Mar 25, 2005 | 09:52 AM
Matt Vassallo's Avatar
lifelong learner
its not adjusted properly
rest in peace tim.
Old Mar 25, 2005 | 10:00 AM
CAPESR20's Avatar
you mean the adjustment under the clutch pedel in the car
Old Mar 25, 2005 | 10:59 AM
launch's Avatar
You'll need it!!!
I am assuming you purchased a new clutch for a reason so why not put it in and adjust it properly????? Problem solved.
Launch It Like It's Unbreakable!!!
Old Mar 25, 2005 | 11:03 AM
CAPESR20's Avatar
just wanted to make sure what the problem might be befor I put a new clutch in and fry it.
Old Mar 25, 2005 | 01:36 PM
Epstein's Avatar
Retired
Sounds like your clutch pedal linkage (under the dash) is too tight, as Mattback said. I will venture to guess that your clutch pedal has zero play. Am I right? Let me explain...
What is probably happening is that the pressure in the clutch line is never completely released, because the pedal linkage is always pushing in on the master cylinder. This will hold the clutch in a semi-engaged position. Being semi engaged (and probably slipping minutely) will cause it to over heat and become slippery. The 20 minutes part is what tells me that it is heat build up that is causing this. This is also very bad for your throw out bearing. Shorten the rod connecting the master cylinder and pedal. You may also have to adjust the bumper that the pedal rests against normally.
Old Mar 25, 2005 | 06:47 PM
ShawnZX's Avatar
Default ...
Did you put clutch in yourself? If so...there is a metal pin that holds the throwout bearing onto the fork comming from the slave cylinder...if it is not tourned the right way it will make the clutch slip when it heats up..the pin looks like it can go either way, but it needs to be turned so that the two bumps on the pin are under the two pieces that go to it on the fork..its very easy to miss...just a suggestion.
Old Mar 28, 2005 | 03:40 AM
CAPESR20's Avatar
thanks for all the help I will take a look at it. And yes I a friend did the clutch for me.
thanks again for the help.
Matt Vassallo
Nissan/Infiniti Tech
41
Feb 22, 2005 07:58 AM
GiDDeNz
4
Apr 11, 2004 11:04 AM
turboralph
Mar 26, 2004 06:49 PM
P_Productions
9
Feb 3, 2004 10:53 PM
Slash
Sep 21, 2003 02:03 PM
