Only running on three cyl HELP
Old Mar 16, 2005 | 10:03 AM
LongFellow's Avatar
Please hold...
Exclamation Only running on three cyl HELP
Its on a 91 s13 KA, it seems that the number one cylinder isnt firing.
the car runs like hell, i have to put my foot on the gas just to get it started and it takes 10 seconds worth or cranking to get it running, it also idles like crap the whole car shakes, and it back fires every time i left off the gas.
i have fuel, my compression is 150 and i replaced my plugs and wires but it seems i have a really weak spark.
it runs the same even when i unplug my injector. so im guessing its something with my ignition?? any suggestions would be of great help.
Thanks
DAn-
Team White Car 2010
Old Mar 16, 2005 | 10:56 AM
Slash's Avatar
THE HAMMER
Do the standard shit..
Plugs , cap, rotor, wires.....
Then if that dosent work, check for a stuck injector.. But do the cheap maintence shit first.
I dont feel like a sig today.
Old Mar 16, 2005 | 11:34 AM
G Dragon's Avatar
he's already done plugs and wires, check for spark, then change distributor if there's no spark.
Old Mar 16, 2005 | 12:18 PM
ZenkiS14_Drifter's Avatar
Wombat S14
id say prolly something in your ign. u chekc your dist. and make sure thats working correctly?
Old Mar 16, 2005 | 12:27 PM
LongFellow's Avatar
Please hold...
i just put on a new dist cap 2 weeks ago, and my injector works fine, the car is spitting out gas like crazy since none of it is getting burned. and there is spark its just not very good
Team White Car 2010
Old Mar 16, 2005 | 02:25 PM
MaxType 240's Avatar
All Around Maxed
You have a leaking injector perhaps. Been there, same symptoms. Check contnuity on your injector harness too.
Jesse
Ings RSpec, Built KA24DET, GT3071R
VR-4 AWD/TT Winter Sled
Old Mar 18, 2005 | 01:25 PM
LongFellow's Avatar
Please hold...
Jesse
I dont think so because the car is running super rich and my old spark plug that was on the cylinder was Fouled up bad.
it was a bosch platinum 4 plug that i had put in only 3 months ago.
but ill check it anyways thanks for the tip.
Team White Car 2010
Old Mar 18, 2005 | 01:37 PM
launch's Avatar
You'll need it!!!
Did you try changing the wire that goes to that plug yet???
Launch It Like It's Unbreakable!!!
Old Mar 21, 2005 | 02:58 AM
All Around Maxed
Sorry for not being clear - I meant torn o-rings on the injector. That was my case, similar symptoms.
MR2driver
Mar 16, 2005 04:06 PM
alri0085
Feb 11, 2005 07:36 PM
coleon
Jun 2, 2004 04:10 PM
BlowncobraGirl
May 19, 2004 07:04 AM
Janky99
Apr 28, 2004 08:12 PM
